Is a ridge reamer really necessary?
Old Jul 14, 2003 | 11:02 PM
ringgold's Avatar
Default Is a ridge reamer really necessary?
Im currently tearing my engine down. Im at the point of where I can remove the rods and pistons. Do I really need a ridge reamer to remove that small little lip at the top of the cylinders to remove the rods and pistons? Im not going to be using the stock pistons so does it matter? Im also gonna be getting the cylinders bored atleast .020 over. So is it really necessary?
Old Jul 14, 2003 | 11:07 PM
Suprdave's Avatar
Default Re: Is a ridge reamer really necessary? (ringgold)
Are you talking about Chamfering the Cylinders?
Use a file and barely take material off...Your just removing the sharp edge. Or have the machine shop do it...but they are just gonna use a file too.
Suprdave
Old Jul 15, 2003 | 12:23 AM
wHOAlly's Avatar
Default Re: Is a ridge reamer really necessary? (Suprdave)
hes talkin about the ridge that forms because of carbon build up when your pulling the pistons
Old Jul 15, 2003 | 08:09 AM
IN VTEC's Avatar
Not necessary unless you find it exceedingly difficult to push the piston out of the bore.
Old Jul 15, 2003 | 09:49 AM
ringgold's Avatar
Default Re: Is a ridge reamer really necessary? (IN VTEC)
Yeah what I was talking about is the little ridge that is made form carbon and what not at the top of the cylinder. I didnt want to try to puch the piston out and have it getting stuck or something if you know what Im saying. I guess I will try just pushing the pistons and rods out tonight.
Old Jul 15, 2003 | 10:36 AM
IN VTEC's Avatar
The ridge is thick enough to catch a nail, but the rings shouldn't be hindered by it.
I had 75k miles on my motor when the pistons came out. They didn't have any problems popping out.
Old Jul 15, 2003 | 10:58 AM
ringgold's Avatar
My engine had 136k on it but the ridge doesnt seem to bad not to the point where the pistons shouldnt slide out.
Old Jul 16, 2003 | 11:12 PM
3rdGteg's Avatar
you should be okay since ur reboring and using new pistons/rings anyways. if u was to reuse the pistons, the ridge can damage the ring grooves on the pistons if the ridge is too big, but ur not, so u should be fine.....
Old Jul 16, 2003 | 11:21 PM
ringgold's Avatar
Default Re: Is a ridge reamer really necessary? (3rdGteg)
Yeah I just pulled the rods and pistons from my block they came out no problem. Thanks for the info anyways fellas.
Old May 27, 2019 | 01:39 PM
THATGUY705's Avatar
Hey guys my h22 has a very slight ridge. You can feel it with your fingernail but it doesn't stop your fingernail from running through. I'm wondering if it's necessary to remove it for the new rings I'm putting in. It will not damage anything going on or coming out but will it damage the rings upon start up or in the future? Thanks
B18aHatch
Apr 7, 2014 07:07 PM
SaM DA Man
Nov 5, 2006 09:20 PM
92eg6lsvtec
Jul 13, 2005 09:42 AM
FoShizzle
Nov 30, 2004 08:53 AM
IN VTEC
Jul 26, 2002 12:14 PM
