P72 connecting rod intensity?
Old Dec 21, 2018 | 12:25 AM
Brembomaster's Avatar
Default P72 connecting rod intensity?
Hello,
My engune running with YCP high compression piston and P72 connecting rod, and now i want to put on the stage 2 cams, but worry to the intensity of P72 rod?
Do I need to replace the connecting rod necessary if i put on the aftermarket camshaft?
Thanks!
Old Dec 21, 2018 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: P72 connecting rod intensity?
Rod bolt failure is going to be your weak point... so as long as you don't intend to increase the engine red line, the rods will be fine. If you rev the engine higher to make more power with the camshafts... I suggest you replace the stock connecting rods with stronger aftermarket ones.
foca
Jan 4, 2008 08:26 PM
d16dcoe45
Nov 15, 2005 05:02 PM
boosted3g
Jan 15, 2003 04:48 PM
HX_Guy
Jul 20, 2001 07:30 AM
