GSR Build for 800whp+
#52
Re: GSR Build for 800whp+
I appreciate that man ! I switched out the 2 450 walboro pumps for a single in tank walboro 525 and gonna put a single pump surge ion the trunk .
Once i'm on dyno i'll def post the results here .
#54
Other parts I used from my subie build so i had them already.. Pays to play man .
Once i finish fueling (still struggling with getting the two pumps to fit) i can do break in and then tune .
Will most certainly update once i go on dyno .
FOLLOW MY BUILD ON IG #B00STED_DC2
#55
Good call on the 60mm wastegate, but I hate to be the bearer of bad news, wg size isn't the only important part, wastegate placement also make a huge difference. The wg has to make almost a full u turn before dumping, they really should have placed it differently so the exhaust would flow into it in more of a straight shot.
Good luck on the build man.
