Checking b20 block for warpage
Old Sep 23, 2018 | 10:54 AM
K-G's Avatar
K-G
Default Checking b20 block for warpage
I have a b series block I’m rebuilding for my eg but im just wondering what size feeler gauge I should use to check the straightness of my block.
I have a d series Haynes manual and I’ve looked in there but I don’t want to go off that because it’s for d series and I’m not sure if it’s the same for b series and just want to be sure. I have tried searching to find such a simple answer for this question as I usually do but cannot find this information for some reason.
Old Sep 23, 2018 | 01:53 PM
K-G's Avatar
K-G
Default Re: Checking b20 block for warpage
Bump
Old Sep 23, 2018 | 09:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Block shouldn't be more than .0015"... chances are good you won't find a feeler gauge set that starts with a thousandths or a thou and a half. You will do better with an engineers ruler and a set of calipers.
Old Sep 24, 2018 | 02:55 AM
K-G's Avatar
K-G
Thanks for the reply. I might have a feeler gauge that has that size. I’m at work at the moment but will check when I get home. Thanks for the reply I appreciate it.
Throwdown
Oct 15, 2018 08:15 AM
EJ2GOON
Engine Management and Tuning
May 1, 2012 05:01 AM
sinister357
Aug 23, 2007 05:30 PM
Ri5e
Feb 26, 2002 07:07 PM
