Checking b20 block for warpage
I have a b series block I’m rebuilding for my eg but im just wondering what size feeler gauge I should use to check the straightness of my block. I have a d series Haynes manual and I’ve looked in there but I don’t want to go off that because it’s for d series and I’m not sure if it’s the same for b series and just want to be sure. I have tried searching to find such a simple answer for this question as I usually do but cannot find this information for some reason. |
Re: Checking b20 block for warpage
Bump |
Block shouldn't be more than .0015"... chances are good you won't find a feeler gauge set that starts with a thousandths or a thou and a half. You will do better with an engineers ruler and a set of calipers.
Thanks for the reply. I might have a feeler gauge that has that size. I’m at work at the moment but will check when I get home. Thanks for the reply I appreciate it. |
