Opinions on drifting?
Definately. For most of your on-road, stock setup applications, it is simply faster to nail the apex of the corner and get it right. Puts a smile on my face every time.
See? -->
See? -->
And how does that picture show that drifting is advantageous?
WRC is huge.
CAR manufacturers put major money into it. Watching Rally Acropolis every year while growing up in Greece I would see about 10 tractor trailers supporing a single car.
Each team needs to win, therefore they need to complete each stage as fast as possible.
In dry pavement, in certain curves, drifting is faster than brake turn and go.
They do not USE DRIFTING FOR SHOW. They use it becasue it is the fastest way around CERTAIN corners.
I really cannot see how can somebody argue about this?????
How? Let's see the easiest way for me to put this.......
WRC is huge.
That proves the point
That is what the car is set up to do. Try taking a dragster through some esses. Sure it will make it through but what is the likelihood of it clipping the apexes? Slim to none. Does that mean that off-line non-apex cornering is the best way through that turn? No but that is the best way for that car because it isn't set up to do it the right way.
You can go buy a WRX sti or a Lancia Delta integrale.....
Of course the car will not be setup like the WRC car, but it will be close.
In other words you are saying that it depends on the setup of the car?
The Bottom Line: (for the street drifters)
If your car is so slow that you cannot even take corners at a speed that is exciting to yourself or any passengers, you should go out of your way to lose traction and "drift" though the turn so that you can make up for the lack of excitement caused by you car's lack of ability to go and turn fast.
[Modified by Tom351, 10:18 AM 5/29/2002]
Good point but you cannot go buy a dragster at the dealer.....
Do rally cars spend most of their time on pavement or dirt? Drifting is faster in dirt. We all know this. If they spend most of their time in the dirt why in gods name would they set the car up for pavement? They "make do" for the small segments where they are on paved roads.
Cobra, you are right.
I see your points.
What I want to know is the reason why drifting in dirt is faster?
I see your points.
Drift is a by-product of the driving on dirt. They power through the turn and pray it hooks before they hit a tree or a tire wall.
I could be wrong but I don't think that if they didn't have to, they would make the risk of drifting into a tree or crowds.
I don't know why drifting in the dirt is faster. I don't do it.
And I stand corrected - evidently F1 cars are set up to drift. Look at what I found:
What were we thinking Tom?
I would say that it is faster in dirt because loose dirt has so much less grip than pavement. You rotate the vehicle in a way that your tire spinning attempt at forward acceleration is also adding to your cornering force. If you are going to slide anyway, why not use you engine to try to stay out of the woods? IOW, breaking tires loose is a big loss on pavement, but not a such big loss (grip-wise) on dirt.
Note: the above is just logical (I hope) speculation as I do not race on dirt myself.
[Modified by Tom351, 10:34 AM 5/29/2002]
oh yea, and what's the point of e brake "drifting"? Isn't that just another flashy riceboy trick?
No it isn't. If you think that you are almost getting a WRC car when you buy a WRX then you are one of the biggest fools alive. Do you think that you almost get a World Challenge car when you buy a Type R?
Other cars like the 206 (Above) are POS fwd cars in production
-C Who would love to own in a road rally prepped awd 206.
xknowonex
Other Make Vehicles
59
Jun 4, 2010 12:17 PM
Ottoman
Aug 4, 2004 05:10 PM
