unichip
Old Aug 14, 2004 | 07:07 PM
12SecHatch's Avatar
Default unichip
is anyone here running one? or know anyone
i have never heared of this thing untill i was introduced to a new shop here in san antonio
they had a stock b16 in a crx with there own turbo kit running 11'40's on 6psi tuned on the unichip
has anyone seen better with the unichip
Modified by 12SecHatch at 10:39 AM 8/17/2004
Old Aug 14, 2004 | 08:21 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: unichip (12SecHatch)
It only works if you have a unibrow.
Old Aug 14, 2004 | 09:53 PM
ModenaTwinTurbo's Avatar
Default Re: unichip (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">It only works if you have a unibrow.</TD></TR></TABLE>
thats funny....
they are big in the wrx world.... well actually i havnt been around in over a year so i'm not sure if anyone is still using them....
they work like the afc only with alot more parameters to adjust.... and theres also boost controll options, if i recall correctly no boost by gear.... i am not sure if it only works on ecu's that already are controlling boost tho..... but you might be able to controll a stepper motor through it for boost, it does have a few interesting features.... you can view a 3d map for both fuel and timing.... and probably the best thing about it is that u can adjust timing....
now for the :thumbs-down:
they are hard to tune.... you need a laptop.... and you cant buy the equipment to tune them, only dealers are allowed to tune them.... and they are still piggyback, even tho they are THAT expensive..
Ed-
Old Aug 14, 2004 | 10:00 PM
1 2 NV's Avatar
i must b missin something. stock B16 in a CRX thats runnin 11.40s on 6psi, yeah right. ill believe that when i see it. unless the CRX weighs 1300lbs.
Old Aug 14, 2004 | 10:03 PM
Default Re: unichip (1 2 NV)
wow i totally missed that.... but it might be possible, big enough turbo i guess..
Ed-
Old Aug 15, 2004 | 07:13 AM
12SecHatch's Avatar
Default Re: unichip (ModenaTwinTurbo)
car ways 2250 car and driver
ill get the full specs on the kit in a bit
Old Aug 15, 2004 | 10:13 AM
Used2beAb16's Avatar
Its a good tool, especailly if your in a place where you need to be running the stock ecu for Emmissions scanning. Its give you control of revlimit, timing, fuel, n20 control, boost, etc, but still in piggyback form.
Old Aug 15, 2004 | 10:36 AM
TurboJesse
Guest
Posts: n/a
Default Re: unichip (Used2beAb16)
ive seen a few people running it (mostly on apps where cheap/good fuel management isn't available). For a honda theres better options for cheaper/free.
Old Aug 15, 2004 | 01:00 PM
Default Re: unichip (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote"> Its give you control of revlimit, timing, fuel, n20 control, boost, etc, but still in piggyback form.</TD></TR></TABLE>
you can lower rpm limit but you canot increase it... n2o control, boost, etc you need to buy extra drivers for theese things along with the solenoid for the boost controler...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote"> For a honda theres better options for cheaper/free.</TD></TR></TABLE>
there is deffinitley better options for hondas for sure... i would never in my life go with a unichip for a honda unless i was a dealer with my own dyno...
Ed-
Old Aug 16, 2004 | 08:18 AM
sci motorsports's Avatar
the car in question is a crx weighing 2250 with driver, it had an ls/vtec, and an SCI Motorsports stage 2 kit with a t3/60-1, from cheap turbo. the tial wastegate was setup with a 5.8 psi (little red spring). the tune was very conservative and on 93 octane at san antonio raceway.
we tune the unichip the car was not tuned on a dyno
Old Aug 16, 2004 | 08:44 AM
Quik Chris's Avatar
Default Re: (sci motorsports)
I totally believe that. I had a stock GS-R in the GS-R chassis with a drag kit (no boost controller) and I did 12.80 @ 99 where the boost pipe popped off at the 1000' mark. I turned teh car off and coasted across, and that's up here at 6000ft.
I'm sure with a lighter chassis and a larger turbo it's more than possible.
But on topic, I think a better option would be to save up a little more money and get something like AEM so you can tune it w/o the dealer.
Old Aug 16, 2004 | 09:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ModenaTwinTurbo &raquo;</TD></TR><TR><TD CLASS="quote">
There is a local tuner here that tunes with the unichip and i was told that rev limit could be raised but you will need to by another plug-in for it, i believe it wa another $50 dollars.
Ed-</TD></TR></TABLE>
Old Aug 17, 2004 | 09:11 AM
the cost of the whole setup rivals with hondata's cost and can be tuned just as easily. we tune unichip and the reason we went with unichip is the diversity of the system. we can run them on anything from a ford diesel to a porche 996 to a geo. with proper instalation and knowledge on the system you can provide water injection, progressive nitrous and progressive boost control. even though you have to purchase different modules for the rev limiter and vtec crossover, the cost of theese modules is inexpensive and are readily available. just like hondata it is best to have an authorized tuner instal and tune the unit.
Old Aug 17, 2004 | 10:57 AM
BoostedEF's Avatar
This is what Im running . The only bad thing is that not to many shops run it so basically your stuck with one tuner .
Old Aug 19, 2004 | 11:42 AM
ZoRG's Avatar
Default Re: (BoostedEF)
They make/design them locally a few kilometres from where I live(South Africa), these were one of the first if not the first piggy back systems ever... its no standalone, but it works well if the tuners know what they are doing. I've heard of two local boosted honda motors blowing up, but turbo honda motors are only a handful here and people don't really know how to tune them yet, so I'll blame it on the tuner in that case...
If dastek tuned it I don't think there would have been a problem.
ej1252
Nov 2, 2007 02:41 PM
ras
May 3, 2005 09:14 AM
Sam1am26
Nov 26, 2004 06:51 PM
boosted jetta
Mar 22, 2004 09:23 AM
HotRodTeg
Oct 4, 2003 12:27 AM
