which trans is better
Old Apr 26, 2007 | 11:31 AM
coolcatsi's Avatar
Default which trans is better
ok here is my set up. ls/vtec 11.5 cr, type r valve train, right now im hitting 14.4 at 93 mph in the quarter. i currently have a stock b16 trans. i want to no what you guys think of a gsr trans with possibly a 4.7 final drive. which would be better. will i see any differance.
Old Apr 26, 2007 | 11:35 AM
MrParks's Avatar
Default Re: which trans is better (coolcatsi)
use your trans, and try out some gears from mf factory, i hear people are having great results with them
https://honda-tech.com/zerothread?id=1832708
Old Apr 26, 2007 | 11:41 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: which trans is better (MrParks)
Hey Jason, did you end up going testing on that gearset?
Old Apr 26, 2007 | 11:56 AM
MrParks's Avatar
Default Re: which trans is better (Clayton)
i will be leaving tomorrow after work to las vegas drag strip for the midnight mayhem test session. since psca racing is throwing a venue out there, it should be prepped very well as it always is. i have 3 trannys i will be testing, they do look really promising! the first one is a stock gsr with 3.07 first, next is a 4.785 final gear set, with 3.07 first and ls gear sets 2 through 4. and the last of the bunch will be a b16a2 trans with a 4.05 final, 3.07 first and factory 2 through 4.
they are all within a couple of mph of each other, but the main focus of the test is to see how well they can hold up to the beating i can give since i always have a thing about breaking.
Old Apr 26, 2007 | 12:04 PM
Big Teggie's Avatar
Stick with the B16 transmission.
Old Apr 26, 2007 | 12:10 PM
MrParks's Avatar
Default Re: which trans is better (Big Teggie)
best for last! the 4.05 mfactory will be much easier on the trans from what i was told. also since its a forged piece its much stronger then the average ring gear from honda. i want to try and abuse them as much as possible and will be giving a detailed report about the test session for everyone to see. i dont know if i have enough time to do all of them fri but i am willing to stay the weekend as well to get it done.
Old Apr 29, 2007 | 01:37 PM
C and D Performance's Avatar
stick with the b16 tranny and get a 4.7 final
Old Apr 30, 2007 | 02:00 PM
RaceProfessor's Avatar
Default Re: which trans is better (C and D Performance)
I would be more concerned about the low mph. I've seen SI's with I/H/E go 93mph. With a 11.5:1 LS/Vtec, I would expect a bit more than 93mph traps.
DaFredsta
Oct 10, 2011 07:58 AM
alwaystootall
Aug 23, 2009 08:53 AM
coolcatsi
Jun 5, 2007 06:52 AM
hybridpatient95
14
Apr 7, 2005 04:47 AM
