Which traction system?
Old Jan 21, 2003 | 10:06 PM
G3gsr's Avatar
Default Which traction system?
Competition Engineering Traction System or Z10 Radius Arm Traction System?
Old Jan 21, 2003 | 10:09 PM
wHOAlly's Avatar
Default Re: Which traction system? (G3gsr)
http://www.jimfab.com
Old Jan 22, 2003 | 08:59 AM
rolow's Avatar
I would go with the http://www.jimfab.com one to!
I hear the Competition Engineering one has a really poor turning radius and there was a thread awhile back about the incorrect mouting points of the Z10 kit causing it to bind.
I have the z10 kit with no problems but would like to give the Jim Fab kit a try
Old Jan 22, 2003 | 08:52 PM
G3gsr's Avatar
Default Re: Which traction system? (rolow)
can the z10 be used on the street?
Old Jan 23, 2003 | 03:50 AM
rolow's Avatar
I use mine on my daily driver
Old Jan 23, 2003 | 07:21 AM
20lb.teg's Avatar
Well, now that we have the reviews of the z10 I will be able to give everyone reviews of the jim fab one very soon Jim promises . Well I have heard that these smote all so I hope they do...
Later,
Sean C.
Old Jan 23, 2003 | 11:18 AM
G3gsr's Avatar
Default Re: Which traction system? (20lb.teg)
Y cant the jimfab one be used on the streets? Y is the jimfab one better then the z10?
[Modified by G3gsr, 8:20 PM 1/23/2003]
Old Jan 23, 2003 | 09:01 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
I heard that z10 only made the CRX Crossmember correct. The ones for the 92-UP civic/integra's were not made right.
Glad i got a crx hehe.
Old Jan 24, 2003 | 12:13 AM
96dc2's Avatar
search this forum for an old thread on traction bars.
oh yeah....jimfab gets my vote.
click this link.
[Modified by 96dc2, 2:15 AM 1/24/2003]
Old Jan 24, 2003 | 01:25 AM
G3gsr's Avatar
Default Re: Which traction system? (96dc2)
Thanx guys Im goin jimfab! Its cheaper and it seems to be better!!
Old Jan 24, 2003 | 05:26 AM
1506's Avatar
Will the jimfab fit if you are boosted and have a big front mount?
Old Jan 24, 2003 | 08:53 AM
G3gsr's Avatar
Default Re: Which traction system? (1506)
"JimFab.com's replacement cross member is made from 4130 chromoly tubing and oversized steel brackets. This unit helps to lessen the harsh shuttering that the Civic, CRX, and Integras receive when under hard acceleration or high speed turns. This unit will also help to improve 60 foot times, not to mention the generous amounts of room it leaves for 4 to 1 headers or turbo kits. You will not find a better built part!!! This cross member uses high quality oversized Teflon lined rod ends, CNC machined parts for the radius rods and end cups, you will be impressed. The CRX cross member will work with a B-series swap. Not recommended for street use." -jimfab
Old Jan 24, 2003 | 02:34 PM
dmotoguy's Avatar
what are the reasons to not run these on the street?
Old Jan 24, 2003 | 03:04 PM
earl's Avatar
Default Re: Which traction system? (dmotoguy)
JimFab is by far the best. His site might say not for the street but that is just for legal purposes. Turbos are usually not smog legal either but everyone does it
None stronger than Jim's
Old Jan 25, 2003 | 01:20 PM
1506's Avatar
Default Re: Which traction system? (earl)
I guess I will have to go ahead and order one.
Old Jan 26, 2003 | 06:40 PM
J2turbo21's Avatar
I did a search for you and here it is:
https://honda-tech.com/zerothread?id=376166
Old Jan 26, 2003 | 11:30 PM
96dc2's Avatar
Default Re: Which traction system? (J2turbo21)
i already linked this above dude.
paton5g
May 20, 2008 09:12 PM
vvtli78k
Mid-Atlantic (Sales)
Dec 6, 2005 07:01 AM
BrianZ
22
Jun 29, 2004 02:01 PM
mityVR6
Feb 23, 2003 11:09 AM
