slicks question
Guest
Posts: n/a
well, i have some 13x8 weld magnums...sitting on 24.5x8x13 MT's.
I have a 96 itr swap...that dynoed 191/132.4 BEFORE my cam install....so i'm eaisly over 200whp now...with possibly...135-138 tq....
are these slicks overkill? if not..what psi should I run?
i'm just not wanting ot kill some axles and what not...
aslo, i have some 22/8/15 MT's on enkei RPO1's
would these be better suited for my car right now?
and if so...what PSI should i run them at??
my clutch is MORE than enough to handle them.
its possible to push the 24's but is a bit overkill for your HP and Tq setup. I'd choose a 22" or a 23" before going up to a 24"
24s is something you'd use at mid 200s and up.
Hey I have a boosted ls in the making and have a set of 24.5x9x13's and its going onto my 91 crx, i was wondering what offset rims to use, what offset are your weld rims, and btw 24.5's arent too much overkill, i ran 22x8x13's last year on a mini-me d-series and had no prob warming them up, took almost 1 second off my time.
Guest
Posts: n/a
i just got the welds in trade for an itr tranny...so i'm really not sure what the offset is...but i'll go see if i can find out
and i have an s4c with no LSD right now...goign to be getting some kinda of lsd as soon as i get all my boost stuff together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow »</TD></TR><TR><TD CLASS="quote">i went and took one off....and it doesn;t say anywhere on it
i suppose, if i get the gumption, i could get a ruler and measure it sometime.
it's the distnace from the hub to the inner lip? or the outer lip?
help?</TD></TR></TABLE>
Hub to inner lip. That's the backspace though. Take the backspace and minus 4". You'll get the offset.
The 22's will be better on your axles for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow »</TD></TR><TR><TD CLASS="quote">i just got the welds in trade for an itr tranny...so i'm really not sure what the offset is...but i'll go see if i can find out
and i have an s4c with no LSD right now...goign to be getting some kinda of lsd as soon as i get all my boost stuff together</TD></TR></TABLE>
You traded an itr tranny for a set of welds? The itr had a oem lsd already, you would benefit more from the itr tranny and smaller slicks than a stock diff and larger slicks.
T.
T.
J28S
19
Sep 1, 2005 05:40 AM
