quick question about slicks...
Old Jan 23, 2003 | 04:57 PM
1qWiKhAtCh's Avatar
Default quick question about slicks...
i have a pair of M/T 20/6/14 slicks mounted on civic steelies, and i was wondering if this size was ok for the setup i'm running...i need ur opinions....oh yea my setup is in my sig....thanx guyz
Old Jan 23, 2003 | 05:26 PM
NX_LS's Avatar
Default Re: quick question about slicks... (1qWiKhAtCh)
Um, if I were you, I'd get a VERY strong clutch, so that you can slide it out. Slicks grab quick, and are harsh on the axles. You'll need to slide it out to prevent yourself from snapping the axles.
Old Jan 23, 2003 | 06:10 PM
gsrvx's Avatar
New User
Just drop the clutch. That's what I do.
-Rod
Old Jan 23, 2003 | 10:02 PM
ExospeedAMcrx's Avatar
teh 6" wide is too small in my opinion. if using 14" at least get the 8" wide slicks
Old Jan 23, 2003 | 11:45 PM
ninesecrx's Avatar
Default Re: quick question about slicks... (exospeedAMcrx)
I think its a little thin as well, but better then running on street tires im sure.
Old Jan 24, 2003 | 02:39 AM
Mista Bone's Avatar
D Tranny Guru
the 6" slick will barely hook up with a NA SOHC motor. With B power, good luck!
Old Jan 25, 2003 | 07:59 PM
skunkwhat's Avatar
Default Re: quick question about slicks... (Mista Bone)
Had same set up as you(c5), and the slicks would spin on launching. Shitty 60 ft's 2.2 try to get 22x8x13 if you can, and if you plan on getting cams ect. i have 20x8x14 and they spin on my car, but i'm getting 2.0's so they half *** work.
1DayIllBFast
Apr 21, 2009 10:14 AM
RaceProfessor
Dec 8, 2005 07:56 PM
LSVTEC 91 Civic
Apr 2, 2005 07:17 PM
BauleyCivic
Sep 11, 2004 09:49 PM
1qWiKhAtCh
Jan 5, 2003 03:00 PM
