slick question ?
Old May 21, 2002 | 08:28 AM
PM-Performance's Avatar
Default slick question ?
can i get bigger slicks on a saet of 15x7 or 15x6.5?
right now i have 22/8/15's and they dont have enough sidewall to give me the traction i need now . . too much power for these small slicks.
i dont want to do 13's yet, i can get the hub assemblied for like nothing . but not ready to get all kinds of new wheels for street, snow and track along with new tires for all 3 . too much money
Old May 21, 2002 | 08:38 AM
hybridreams's Avatar
Default Re: slick question ? (itr206)
I wouldn't go much bigger, if I recall, someone on here had trouble fitting slicks (8width) on some 13s (6, or 6.5). Not sure if he ever got it to fit right or not
Old May 21, 2002 | 08:44 AM
Default Re: slick question ? (hybridreams)
i saw that , but i was thinking maybe 8/24/15, i need more sidewall . my 8fit great on my 15s and ive been running for a while now. i just need more sidewall to actually get traction .
Old May 21, 2002 | 08:48 AM
MPH's Avatar
MPH
New User
What psi do you run? I seen another thread where you said you couldn't get better than 2.0 60's. I have the same slick and I get low 1.9's all motor with 13 psi.
Old May 21, 2002 | 08:56 AM
Default Re: slick question ? (MPH)
i was prev running like 15-16 psi . i think im gonna drop em to 11-12 to see if that helps. . . i cant even get lower than 2.0 60ft. its driving me nuts. i should be like 1.8s all motor and 1.7 maybe with nitrous.
its just not working for me any more
Old May 21, 2002 | 09:05 AM
MPH's Avatar
MPH
New User
Yes, 15 psi is too much. 12, 13 psi warm will work alot better. I'm gonna experiment with 10 psi next time out
[Modified by MPH, 1:06 PM 5/21/2002]
Old May 21, 2002 | 09:09 AM
let me know how it goes. im gonna try lower psi before i start spending more money.
do you have wheel screws in yours?
Old May 21, 2002 | 09:23 AM
MPH's Avatar
MPH
New User
No wheel screws or tubes. 22x15x8 mounted Kosei k-1's. I also don't do burn outs. Just a quick scrub thru the waterbox.
Old May 21, 2002 | 09:48 AM
really? i have no tubes nor screws, but do a hella burnout.
Old May 21, 2002 | 10:00 AM
MPH's Avatar
MPH
New User
It's recommended not to do burn outs with these slicks. Just a quick little one and that's it. Maybe that's your problem. After you heat them up your probably at 18 psi or so.
Old May 21, 2002 | 10:23 AM
i thought i heard that somewhere too , but one of the guys in my club told me the hotter the better. so i get em reallll hottttt. "he knows everything "
ill try it a couple diff ways , ill try just a quick scrub , and then ill try it with less pressuer and a reg burn out and see what works. . . .thanks
Old May 21, 2002 | 10:28 AM
MPH's Avatar
MPH
New User
No prob. Now with the quick scrub you must run lower pressure.
[Modified by MPH, 2:28 PM 5/21/2002]
Old May 21, 2002 | 10:32 AM
sgT's Avatar
sgT
Not with those slicks.
Old May 21, 2002 | 10:33 AM
apexii's Avatar
I also get 1.9's allmotor on my 22x8x15 MT's. They're mounted on 6.5" stockers. No tubes, 11-12lbs.
Who makes the 24" you talk of?
The 26" seems to be the only other option from MT, but that would be overkill for you. M&H has a new line of slicks, the HB series. They offer a 8.5/24.5/15 and 9.2/24.0-15 but I have not seen them yet.
Old May 21, 2002 | 10:41 AM
Default Re: slick question ? (apexii)
i thought i saw mt with those. ? maybe i was hallucinating?
i just dont want to spend the money right now . i want to find a way to do it with these.
i have the hubs and stuff to swap them to 4 lug, just no money for more tires and wheels.
Old May 21, 2002 | 12:12 PM
apexii's Avatar
I don't think MT makes a 24x15 slick, but things change so who knows. I know M&H has a new good compound, and will be my next choice.
Old May 21, 2002 | 12:13 PM
sgT's Avatar
sgT
MT makes a 24.5x9.5x15 or somewehere around there
Old May 21, 2002 | 12:15 PM
MPH's Avatar
MPH
New User
Default Re: slick question ? (sgT)
M&H has a 23x7x15 I believe.
Old May 21, 2002 | 12:24 PM
apexii's Avatar
9.5, lol!
I will check into that....
Old May 21, 2002 | 12:28 PM
apexii's Avatar
Steve, I think that's a 13" tire. This is taken from their site:
3012 24.5/7.0-13
3014 24.5/8.0-13
3016 24.5/9.0-13
3017 20.0/6.0-14
3018 20.0/8.0-14
3020 26.0/8.5-14
3024 28.0/9.0-14
3019 22.0/8.0-15
3052 26.0/8.5-15
3053 26.0/10.0-15
Old May 21, 2002 | 12:33 PM
sgT's Avatar
sgT
no, i saw it, not in a catalog but in person.
check M&H but im 99% sure they were MT.
Old May 21, 2002 | 12:41 PM
hey apexii ? wheres lansdale at?
how far are you from like reading? allentown? area?
Old May 22, 2002 | 07:03 AM
apexii's Avatar
yo, lansdale is about 30-45mins from allentown on the turnpike... Are you near downingtown? I was up there for a dyno day with a bunch of members on here...
Old May 22, 2002 | 07:12 AM
kinda sort abut not really. . . im prob like an hr maybe from downing town .
boostedb20z
Apr 14, 2009 05:29 PM
Soled Out
Jul 31, 2003 10:36 PM
UNDER PRESSURE
Apr 21, 2003 03:25 PM
92JDMSiR
Apr 18, 2002 06:52 AM
Louie
Aug 20, 2001 05:50 AM
