Removing ABS, ,. . . Kinda Drag racing related, weight savings
I need to know what lines come out of the abs system , but still alow my brakes to work , i took out the ABS unti so far andgot the push pins detached back to the firewall, now i need to knwo what comes out from there so i can get the engine compartment cleaned up. Also what size plugs will i need to plug up whats needs to ,
Thanks.
Thanks.
Re: Removing ABS, ,. . . Kinda Drag racing related, weight savings (itr206)
Pete you wont need to plug anything you just need a few parts from a non abs car. You will need the frnt 2 bake lines from a RS integra and the proportioning valve also. The hard parts to get are the brake booster and the master cylinder. They are different on a non abs car. I did this to my teg and it works fine. Give me a call i think i have most of the items you need. 717-397-4476
Re: Removing ABS, ,. . . Kinda Drag racing related, weight savings (boosted3g)
cool thanks . Lynn told me we could do it with what i had tough he said i need i forget what they are, but some kind of plugs to plug up where some of the lines are. Ill give you a call in a few.
wow, good luck with that. it is not easy
Im pretty sure migs did that or someone else that posts alot in the itr forum
good luck with it though, it should be a cool setup
rob, who has his abs light on and abs doesnt work, well who cares the head is 300 miles away right now
Re: Removing ABS, ,. . . Kinda Drag racing related, weight savings (Bob-DC2)
Well boosted 3G gave me a run down of what needs to be done , Thanks JOsh .
Will the abs light stay on , or can i pull the fuse? also will the abs relay box /fuse box totally come out,or will that need to stay in cuz of the harness?
I did that to my GSR a couple months back. It's definetly a fun project. I made my own front hard brake lines that I picked up from a local parts store and I had to get a proportioning (sp?) valve from a non ABS car. I used the same master cylinder and brake booster and the brakes work fine. I'm not sure why boosted3g said you need to change the master cylinder out......maybe you need to change it to utilize the RS front brake lines because the mounting spots on the RS Master cylinder are different than the ABS cars? Good Luck.
Modified by skunked at 8:49 PM 7/1/2003
Re: Removing ABS, ,. . . Kinda Drag racing related, weight savings (skunked)
yea im not sure. ill prob end up asking if he'll come down and help since he already knows how to do it
