Quad stage boost control triggering?
Old Nov 29, 2005 | 05:10 PM
AutoLab's Avatar
Default Quad stage boost control triggering?
I am interested in one of the quad stage control systems on the market, havent decided which one yet. My main question is, how are you guys triggering the system? I obviously dont want to use flip switches and it seems a timing system would take a lot of time to setup. Thanks for your time
Old Nov 29, 2005 | 05:14 PM
Jared's Avatar
you could weld a peg on your shifter that triggers a flip switch for each stage, or you could trigger it through your engine management.
Old Nov 29, 2005 | 05:16 PM
hondaguyef's Avatar
Default Re: (Jared)
You can use the OE clutch switch.
Phil
Old Nov 29, 2005 | 05:21 PM
Turbo-charged's Avatar
Default Re: (hondaguyef)
wire in a bunch of strobe lights under your car. and every 65th blink it will raise the boost. it will be awesome.
but most people either use MPH on their engine managment or a button on the steering wheel. i dont like the clutch switch idea.
Old Nov 29, 2005 | 05:27 PM
hondaguyef's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote"> i dont like the clutch switch idea. </TD></TR></TABLE>
Works very well w/ the Innovative BC. Ask Felix and Dan Back
Phil
Old Nov 29, 2005 | 06:05 PM
last time i saw felix at the track he couldnt get his boost controller to work haha.
it has worked well for them in the past, and worked well for many others....its just not something that i care for personally thats all. i havnt deciddd what im going to do for boost controll next year either so im in the same boat
Old Nov 29, 2005 | 07:10 PM
Aggressive Racing's Avatar
Innovative is the shiznit,wire it up with a relay to the stock clutch switch,use a 15lb spring in the wastegate,read the manuel and go nuts.
There are different ramp setting that can make the boost come in hard or gradually.Iv'e sold 6 in the past 2 months and the customers swear by it.
Old Nov 29, 2005 | 07:14 PM
Default Re: (aggressivemotorsports)
im considering one next year possibly......whats a round about price of what they go for
Old Nov 29, 2005 | 07:16 PM
tony1's Avatar
Joe, i'd use that NLR controller and base it off of time. You can do gear with it as well if you decide to do that route. I think it's a much better controller than the Innovative, alot easier to get to work properly anyways.
Old Nov 29, 2005 | 07:22 PM
WTR's Avatar
WTR
Default Re: (tony1)
where do you get the NLR boost controller and how much does it cost compared to the innovative
Old Nov 29, 2005 | 07:25 PM
the time based is a little complicated,(especially Joe being a 1 man team)it takes a lot of playing with ,i found in our class with no wheelie bars and such, no 2 runs are ever the same,so for one run you might get it right,the next you might be off.but on the clutch it never fails.
Old Nov 29, 2005 | 07:27 PM
Default Re: (tony1)
never even heard of it? link?
Old Nov 29, 2005 | 07:43 PM
seen4ever's Avatar
its one of the sponsors, i've seen it pop up there a few times. It allows CO2 control.
since autolab is using autronic as an EMS, I think they are limited to 1 output left, if they removed the GM boost selenoid. So that's just going from stage 1 to stage 2. I prefer a gear based boost controller, as for me, time would just kill me as i'm so damn inconsistant.
The NLR does look pretty nice though, not overly expensive for having the ability to control CO2.
Old Nov 29, 2005 | 10:23 PM
V-SPEC 1's Avatar
How about the AVC-R, can be program by gear and rpm. I like it so far.
Old Nov 29, 2005 | 10:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">never even heard of it? link?</TD></TR></TABLE>
http://www.nlrsystems.com/
Old Nov 29, 2005 | 10:58 PM
SpeedDreamz.com's Avatar
Default Re: (Arturbo)
That is a pretty nice piece.
Old Nov 30, 2005 | 04:14 AM
Default Re: (V-SPEC 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">How about the AVC-R, can be program by gear and rpm. I like it so far.</TD></TR></TABLE>
ive been using the avcr for like 5 years. nice for street driving but not for me at the track (however thats what i ran this year...actually i still have it i need to sell it)
Old Nov 30, 2005 | 04:20 AM
thanks art.
hmm looks super nice. i'll have to check into it more. anybody used it? pretty easy to set up? and easy to make changes at the track with out having to get a computer science degree?
Old Nov 30, 2005 | 04:22 AM
Arturbo's Avatar
Better than steak
25 Year Member
lets just say tony loves it.
Old Nov 30, 2005 | 04:23 AM
Turbocivic94's Avatar
I was using turbo xs quad stage boost controlled with neptune and it works well.
Old Nov 30, 2005 | 07:48 AM
tommyten's Avatar
doesnt it cost like $750??
Old Nov 30, 2005 | 07:51 AM
tony1's Avatar
Default Re: (tommyten)
$850, good stuff costs money...
Old Nov 30, 2005 | 07:58 AM
tommyten's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">$850, good stuff costs money...</TD></TR></TABLE>
then they might as well buy motec then
Old Nov 30, 2005 | 08:03 AM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aggressivemotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Innovative is the shiznit,wire it up with a relay to the stock clutch switch,use a 15lb spring in the wastegate,read the manuel and go nuts.</TD></TR></TABLE>
Thats how I wired mine up We used a .5 WG spring and that controller still held 34psi.
Old Nov 30, 2005 | 09:28 AM
Default Re: (GITWIDIT)
so how does this controller work compared to either AEM or Motec's boost controll through the software?
