Pros/Cons of different slick sizes?
Old Nov 17, 2002 | 12:24 AM
gsrvx's Avatar
New User
Default Pros/Cons of different slick sizes?
Can someone explain to me the advantages/disadvantages of slicks of different sizes? I'm a beginning when it comes to slicks. I've probably had a total of 10-11 passes on 20x8x14 m/t drags.
-Rod
Old Nov 17, 2002 | 08:23 AM
Jared's Avatar
Default Re: Pros/Cons of different slick sizes? (RK)
taller slicks will give you a taller gear ratio but are much worse on axles. shorter slicks are easier on axles, but shorten your gears and will spin easier with lots of power.
Old Nov 17, 2002 | 08:52 AM
ExospeedAMcrx's Avatar
well choosing the right slick size first deals with the Slixck height your car can probably push. a basic bolt one and some internal mods can push the 20" tall slick, but will probably overpower it pretty quickly as you increase in HP. so the next step is a 22", you would step up to a 24" as you go TURBO or reach 250hp or more.
as far as width, most of us honda guys will use 8" wide tires, but as you increase in HP, you want more traction and some choose to bump up to 8.5 to 9"
if you are not pushing enough HP, the wider slick may not be that great at the top end and you may lose HP.
Old Nov 17, 2002 | 10:06 AM
redcxhatch's Avatar
-Rod
The Bigger the contact patch, the more traction you get! Taller tire = longer gears, but bigger contact patch, smaller tire = shorter gears, but narrower contact patch.
[Modified by redcxhatch, 7:07 PM 11/17/2002]
Old Nov 17, 2002 | 10:27 AM
D-Man's Avatar
Default Re: Pros/Cons of different slick sizes? (Jared)
i always thought the taller slicks would be easier on the axles because the extra sidewall absorbs alot of the initial shock of a launch.
[Modified by D-Man, 8:23 PM 11/17/2002]
Old Nov 17, 2002 | 01:50 PM
gsrvx's Avatar
New User
Thanks for the responses guys
-Rod
Old Nov 18, 2002 | 01:44 AM
Mista Bone's Avatar
D Tranny Guru
Geez, I have to write a magazine article on this subject.
Did I mention it is due by Turkey day?????
TurboEK9Coupe
Mar 19, 2008 07:48 AM
tyrone27
Dec 10, 2006 07:03 PM
RaceProfessor
Dec 8, 2005 07:56 PM
ACRXGuy
Apr 2, 2003 12:20 PM
1qWiKhAtCh
Jan 25, 2003 07:59 PM
