open diff on slicks??
Old Mar 20, 2005 | 05:38 PM
vwhonda2gether's Avatar
Default open diff on slicks??
i have 22x8x15 m/t slicks and was wondering if the stock diff will hold up. the set is a stock b16a2 with b16 hydro trany in 1989 crx. how miny people are runing open diff and can still drive home when done racing?
Old Mar 20, 2005 | 05:48 PM
2k.civic.si's Avatar
Default Re: open diff on slicks?? (vwhonda2gether)
look here https://honda-tech.com/zerothread?id=1146308
people pull 1.6-1.8 60's with open diff...makes u wonder if lsd is really worth $1000+ to buy/install....
civicguy in that thread said "we have run without it 10.9 put a quaife on it 10.8 stock axles too"
so for .1 difference i can think of better parts to spend your money on...
fyi courtney green in utah runs 10.14... street car with stock axles and open diff
Modified by 2k.civic.si at 3:30 AM 3/21/2005
Old Mar 20, 2005 | 05:50 PM
Default Re: open diff on slicks?? (2k.civic.si)
dang i feel bad for posting this, i searched the other day and didnt find anything thank you very much
Old Mar 20, 2005 | 05:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vwhonda2gether &raquo;</TD></TR><TR><TD CLASS="quote">dang i feel bad for posting this, i searched the other day and didnt find anything thank you very much </TD></TR></TABLE>
dont worry....most people get all mad and say use the search...problem is no one explains how to use the search engine....they just assume people know...most the time you have to select archived to get results
Old Mar 20, 2005 | 06:57 PM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">
dont worry....most people get all mad and say use the search...problem is no one explains how to use the search engine....they just assume people know...most the time you have to select archived to get results</TD></TR></TABLE>
Props for the very civil response rarely seen on HondaTech.
But back to the topic. I plan on using 22x8x13 slicks with my USDM GSR in a hatch. open diff and stock axles. You just gotta hope it will hold up. I'm sure eventually the diff will take a ****. Maybe you'll be lucky.
Old Mar 20, 2005 | 07:57 PM
Default Re: open diff on slicks?? (HondaBullSQ)
thanks again 2k.civic.si very helpfull i have been a meber for some time but still working on the search thing and somtimes dont get anything. and thank you hondabullsq for your input, im going to run them and see what happens i am going to preload it and mess with what rpm to launch it and ride the clutch. will see what happens thanks again
Old Mar 21, 2005 | 05:18 AM
kndaqikEG's Avatar
Look on the bright side, open diff. trannies are cheaper to replace when you blow them up .
Old Mar 21, 2005 | 01:41 PM
fandango's Avatar
umm... ive broken 2 already. one on bfs and one on 22' tall slicks. with a b16 trans. one hydro and one cable. you can try it, but u may not make it home. i have a qauife f/s for a hydro b16. if ur interested give me a pm.
oh... ive ran gsr trans on slicks too. those hold up much better. probably due to their size. its bigger than a b16 trans. havent broken a gsr open diff yet.
Old Mar 21, 2005 | 01:45 PM
Default Re: open diff on slicks?? (fandango)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fandango &raquo;</TD></TR><TR><TD CLASS="quote">umm... ive broken 2 already. one on bfs and one on 22' tall slicks. with a b16 trans. one hydro and one cable. you can try it, but u may not make it home. i have a qauife f/s for a hydro b16. if ur interested give me a pm.
oh... ive ran gsr trans on slicks too. those hold up much better. probably due to their size. its bigger than a b16 trans. havent broken a gsr open diff yet.</TD></TR></TABLE>
learn to launch....my stock s4c hydro tranny has 70k+ worth of beating on it
Old Mar 21, 2005 | 01:49 PM
fandango's Avatar
i know how to launch. i think that i am a pretty good driver.
put some slicks on and launch at 7k-8k and ull see what i mean. its the best rpm to launch. trust me.
1.8 60s
Old Mar 21, 2005 | 01:52 PM
ndogg's Avatar
first of all, anyone can pull 1.8's on slicks, that is by no means a great accomplishment. either way, it doesn't mean you are launching right... you are obviously putting to much stress on your drivetrain.
Old Mar 21, 2005 | 02:01 PM
seen4ever's Avatar
Default Re: open diff on slicks?? (ndogg)
i pulled a 1.68 60 ft with a GSR tranny and stock diff. with stock axles, 355whp sidesteping at 7250rpms. never broke an axle or anything in the tranny. This is with an act 6-puck clutch.
the weakest diffs around are the 99-00 Si trannies. i bought a busted Si tranny from a friend and have put an OBX LSD in it. I just need to replace a few more bearings and i can try it out.
Old Mar 21, 2005 | 11:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fandango &raquo;</TD></TR><TR><TD CLASS="quote">i know how to launch. i think that i am a pretty good driver.
1.8 60s</TD></TR></TABLE>
see what you mean? i own slicks
and a 1.8 60....my point proven...learn to launch....anyone can pull 1.8 60's on slicks after a couple practice runs....hell just dumping the clutch at 7,500 on my m&h 22's pulled 1.8's
Modified by 2k.civic.si at 9:00 AM 3/22/2005
boostedb18kid
Feb 11, 2008 12:22 PM
siblues
Feb 27, 2006 04:42 PM
gSr_jB
Feb 25, 2005 08:19 PM
JDMlyfestyle
Jul 14, 2004 12:27 PM
Snafu-Si
Oct 22, 2003 07:56 AM
