DR's on stock ls axles and no lsd??
I put down 227 tot he wheels in my 94 teg, only at 9 psi. I keep on spinning at the trace off the line and cant deal with sub-par 60 fts. I dont have lsd either, but was wondering if the stock axles would handle a set of DR in the front. It's my daily driver and dont want to snap anything as i work 7 days a week.
-chris-
-chris-
Reject Papi
Re: DR's on stock ls axles and no lsd?? (GRAF-FITI)
why would you want drag radials on a daily driver anyway? unless you race at your job, for a living. yes you will have to worry about axles but you can always upgrade. 7 day work week ftl.
Re: DR's on stock ls axles and no lsd?? (jhammond_82)
you could look into an aftermarket traction bar from avid or full race, there suppose to significantly lower your 60ft times and help you off the line.
well stock axles can hold up to alot theres two ppl where i live and one has 510 hp with slicks on stock axles and has never had aftermarket ones..and the other has way more hp and tq with slicks lsd on stock axles same thing...they always tell ppl the car doesnt break axles the driver does so yea just my input but if you want to buy aftermarket one go righ ahead
95c1v1cs1
05-07-2003 10:14 PM
