o-ring head
Old Dec 20, 2004 | 12:05 PM
evilone's Avatar
Default o-ring head
Anyone have any success o-ringing a h22 head?i have a gasket issue and i have o-ringed blocks before but never a head. Anyone have any info?
Old Dec 20, 2004 | 02:45 PM
nvmyb20hatch's Avatar
Default Re: o-ring head (prostock)
im interested if anyones done that too
Old Dec 20, 2004 | 02:50 PM
GRTechnologies's Avatar
i never had a head gasket problem, and i dont use any o-rings
Old Dec 20, 2004 | 05:45 PM
Jared's Avatar
if you do o-ring, do the block, that makes it much easier to surface the head if it's ever needed.
Old Dec 20, 2004 | 07:43 PM
evilone's Avatar
Default Re: (GRTechnologies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRTechnologies &raquo;</TD></TR><TR><TD CLASS="quote">i never had a head gasket problem, and i dont use any o-rings </TD></TR></TABLE>
you are an endless river of knowledge
Old Dec 20, 2004 | 09:51 PM
Rtype16's Avatar
Default Re: (prostock)
On our drag motors the only thing we did was o-ring the head. Also used the stock head gasket with copper coat and stock head bolts.
Old Dec 21, 2004 | 07:46 AM
DLB1994's Avatar
Default Re: (Rtype16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">On our drag motors the only thing we did was o-ring the head. Also used the stock head gasket with copper coat and stock head bolts.</TD></TR></TABLE>
this is all i got on my street motor every thing he said
coper o-rings in the head
Old Dec 21, 2004 | 10:09 AM
evilone's Avatar
Default Re: (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">
coper o-rings in the head </TD></TR></TABLE>
you use copper orings or stainless???
Old Dec 21, 2004 | 10:48 AM
DLB1994's Avatar
copper o-rings with oem gasket but am only 87.5mm bore
Old Dec 21, 2004 | 01:17 PM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">copper o-rings with oem gasket but am only 87.5mm bore</TD></TR></TABLE>
ever use 90mm with a bored factory?
Old Dec 21, 2004 | 03:08 PM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostock &raquo;</TD></TR><TR><TD CLASS="quote">
ever use 90mm with a bored factory?</TD></TR></TABLE>
i never tried it with 90mm bore
when i had 90mm bore i was using copper head gasket with SS o-rings
For 90mm bore
the oem headgasket will be to small for 90mm bore , but if u have a h22 get u a cometic gasket
Old Dec 21, 2004 | 03:24 PM
evilone's Avatar
when you had the 90mm was the oring in the head or block?
Old Dec 21, 2004 | 03:30 PM
DLB1994's Avatar
head with the darton sleeves the bore was to close to put in in the block safely
but i had bad luck with the 90mm bore with any thing over 15psi , headgasket kelp leaking in boost going in the over flow tank but i do run 10:2.1-10:5.1 comp
Old Dec 21, 2004 | 03:34 PM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">head with the darton sleeves the bore was to close to put in in the block safely
but i had bad luck with the 90mm bore with any thing over 15psi , headgasket kelp leaking in boost going in the over flow tank but i do run 10:2.1-10:5.1 comp </TD></TR></TABLE>
i see, the bore being to close is my issue too, but i'm NA on methanol, so i think if it was good for 15lbs it should be good for 0psi on meth. hopefully
1fastlude1
Aug 16, 2008 06:14 PM
Dartanian
Jun 13, 2006 10:40 PM
Squirtin EGsr
17
Sep 26, 2005 09:13 PM
evilone
Dec 22, 2004 02:37 AM
VanHonda
May 9, 2004 09:47 AM
