Need Help With CO2 boost controller!!!!!
Old Jun 9, 2012 | 05:34 PM
Almtrhb's Avatar
Icon2 Need Help With CO2 boost controller!!!!!
Whats goin on, i need a little help with my time based boost controller. Im usin CO2 and its a innovate controller. If i can remember i have a low spring rate in my WG. Its a single 46mm WG,topmount, 6766 turbo, car made 800+ @30 psi...
I went to test n tune lastnight, Car was setup with 24.5x9 MT @5.5lbs brand new, gsr tranny with 4.2 FD, ..... Now heres the problem.. I have heard of this system searching for boost and adding like 10psi more, or the system not activating.. What CO2 pressure should the bottle be at? I have mine at 50psi bottle pressure
Settings on the controller were timed based in 1 second intervals 14psi, 18psi, 24psi, 28psi, and 32Max boost. I found that setting my boost targets like that was wayyyy toooo much. Car spun 1-3rd gear. 1.7 60'ft
What type of luck have you had with your CO2 boost controller, or how is your's setup. Time based or gear based. or Should i just use my s300 BBG again?
Thanks
Old Jun 9, 2012 | 06:07 PM
Zer0_SpeedWorks's Avatar
Default Re: Need Help With CO2 boost controller!!!!!
Are you using nlr?
The value being added + spring of wastegate. Maybe that is why youre overboosting.
Co2 is added on top of wastegate.
Old Jun 9, 2012 | 06:13 PM
Almtrhb's Avatar
Im using the innovate msbc... And my spring is a yellow and natural which is 4.5lbs
Old Jun 10, 2012 | 03:27 AM
miller's Avatar
Why not use the s300 boost control? I don't really see much I a need for anymore then that.
Old Jun 10, 2012 | 09:36 AM
nonvtecallmotor's Avatar
I used that BC years ago.. It "hunts" for boost bad but it does work ok. It is hard to beat the S300 BBG.
If I was going to use that BC again I would put the map sensor in the top port of the wastgate to measure the pressure like the NLR... Alot more accurate that way.
Old Jun 10, 2012 | 05:19 PM
Almtrhb's Avatar
Yea i've heard it hunts for boost... Damn also i was told that it was overboosting due to too much bottle pressure. Well back to Hondata BBG, we didnt have a problem until we installed that controller.
Thanks for feedback guys appreciate it alot..
Old Jun 10, 2012 | 05:27 PM
Almtrhb's Avatar
Icon2 Re: Need Help With CO2 boost controller!!!!!
Aight Miller, goin back to the hondata BBG, what settings psi wise should i start with? I know every setup is different. But im thinking sumthan like 1-4th 14, 19, 25, 31 as an example. Gsr tranny W/ 4.2 FD, 24.5x9 tire, and 860whp.... or even 12, 17, 26, 31
Thanks for the help just tryning to go fast hahaha...
Old Jun 11, 2012 | 10:49 AM
Almtrhb's Avatar
Thanks for the info...
Old Jun 27, 2012 | 10:06 PM
h22-eg-hatch's Avatar
Bbg ftw
sevenj
May 25, 2008 01:15 PM
94turboeg
Aug 13, 2007 12:08 AM
c61lude
Jan 19, 2006 04:34 PM
GettaluvR
Nov 2, 2002 10:38 AM
Snafu-Si
Mar 5, 2002 02:07 AM
