liberty handcuff install problems!!
Old Aug 3, 2010 | 04:37 PM
94lsvturbo's Avatar
Default liberty handcuff install problems!!
ive been tryin to get my tranny put back together after putting in a new final drive and liberty handcuff, but for some reason i am unable to get my tranny case to set back together. the snap ring on the counter shaft wont lock into it and in not sure if i need to add more shims to the cuff or what!! just curious as to what everyone is doing when they install the cuffs. searched for cuff installs and havent seen anything and liberty hasnt been any help. some install pics or something would be helpful...thanks for any help and sorry if this is considered the wrong section but i figured i would get better response from the drag racers section...
Old Aug 3, 2010 | 04:47 PM
Kevin's Avatar
Default Re: liberty handcuff install problems!!
could be that.. or sometimes i have to pull up on the shaft with a flat head.. or flip the trans over and knock it a little against a piece of wood for the clip to set
Old Aug 3, 2010 | 05:07 PM
94lsvturbo's Avatar
yeah i did all the above and no luck. ive never had this problem before so im not real sure what the issue is. i was curious if everyone uses the shims that liberty ships with the cuff and if i have them in the right spot.. i used 2 shims first and couldnt get the clip to go so then i used the 3rd shim but still no luck...
Old Aug 3, 2010 | 05:15 PM
redboost10's Avatar
libertys will ship the cuff with shims ziptied to it on the top and bottom and thats how you install it. did they not ship it like that to you?
Old Aug 3, 2010 | 05:28 PM
94lsvturbo's Avatar
came with 3 shims and the were ziptied to the bottom and thats how i installed it.
Old Aug 3, 2010 | 05:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
make sure the 3 4 slider isnt installed upside down. look and see how much of the bearing is hanging over the end of the shaft. it should be close to flush.
i have done this a time or 2. hahaa.
Old Aug 3, 2010 | 05:59 PM
sanman000719's Avatar
just dont get frustrated and F some stuff up trying to force it to work man
Old Aug 3, 2010 | 06:18 PM
94lsvturbo's Avatar
lol a lil to late. broke the case already.. shitty luck i have but ill work past it.
Old Aug 3, 2010 | 06:21 PM
SPOOLINmatt's Avatar
check your torque on the countershaft nut, ive had this **** happen before, i had to take apart the countershaft and reassemble it with my brain in check to figure out what an idiot i was for a minute.
Old Aug 3, 2010 | 06:28 PM
94lsvturbo's Avatar
ok cool thanks for some directions guys
Old Aug 3, 2010 | 06:35 PM
ill be in kc tomarrow night at the track prepsring for sunday
Old Aug 3, 2010 | 06:59 PM
Antilag's Avatar
If your case is about 3/8 of an inch from closing, check your top countershaft bearing. When you look at it, it looks even but really it has a slight taper. Install it with the writing on the bearing facing up.
Old Aug 4, 2010 | 03:33 AM
ALL IMPORT's Avatar
^^ very tru it will f u up every time. & dont forget about the washer on the main shaft facing the right way.
also make sure u can pick up the counter shat with your hand so u know it will go up into the snap ring.
Old Aug 4, 2010 | 04:43 AM
94lsvturbo's Avatar
^^ it moves up about an 1/8 in.
Old Aug 4, 2010 | 12:25 PM
94lsvturbo's Avatar
ding ding!!! we have a winner!!! took the gear set apart and installed the 3-4 slider upside down.. im a retard. thanks for all the help guys
Old Aug 4, 2010 | 05:45 PM
Mr. Badwrench
experience is a m er ef er sometimes.....hahaa glad it worked.
mcmmotorsports
10
Dec 24, 2013 08:48 AM
turbolshatch
Mar 17, 2009 08:51 PM
Rod.
Sep 22, 2004 03:11 PM
Neptune
Dec 25, 2002 10:52 PM
boostedcvc
Nov 14, 2002 01:49 PM
