phantom grip install
Old Nov 13, 2002 | 03:15 PM
boostedcvc's Avatar
Default phantom grip install
who here has installed there phantom grip themselves? Should i try it or should i bring my transmission to a tranny shop. the trans. is already seperated from the block and actually sitting in my room.
Old Nov 13, 2002 | 08:39 PM
boostedcvc's Avatar
Default Re: phantom grip install (boostedcvc)
I know it's not the best, but did anyone install one.
Old Nov 13, 2002 | 09:07 PM
paulzy's Avatar
if you haven't done it before, pay someone else or get someone there that has done it...
you have to take out the gearing assembly
Old Nov 13, 2002 | 09:09 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: phantom grip install (paul_vang)
It's not that difficult, but have you actually opened a tranny case and played around in there? If you haven't worked with it before, it might be a bit much.
But once you're in there, it's not that hard to install a phantom grip. Basically you stick it in the diff and release the pins.
Old Nov 13, 2002 | 09:11 PM
tony1's Avatar
Default Re: phantom grip install (shamoo)
I've done it many times, but i wouldn't recommend it if you haven't before or aren't very mechanically inclined.
Old Nov 13, 2002 | 10:41 PM
boostedcvc's Avatar
Default Re: phantom grip install (tony1)
I rather mechanically inclined and i will be attending wyotech in june. What im thinking about doing is taking apart my tranny from my old sohc and seing how difficult it is and then if i can figure it out i will do it on my ls tranny.
Old Nov 13, 2002 | 10:51 PM
AbaZ's Avatar
Ya, my sweet *** fagit grip did this...
The PG put a bit more pressure on one side of the diff pin, seized the gear, and broke the holding pin for the diff. Amazing? well... After 30 mins of trying to get that ******* peice of **** out of my diff, it would not come out, I had to cut my diff housing apart to remove it...
What does PG have to say? : Nothing, Not even a comment
This is my third Phantom Grip I have installed.. The others are still ok, but they were DSM's and they used a stronger spring tension on the PG.
As far as installing it, its pretty easy if you are somewhat inclined.
Jeff Frank
Old Nov 13, 2002 | 10:56 PM
avividmemory's Avatar
Default Re: phantom grip install (AbaZ)
eww that looks nasty...i would much rather opt for the type r lsd, its around the same price if you get it used...and i imagine it is quite better...
anyone else have dealings with the PG?? im curious
Old Nov 13, 2002 | 11:11 PM
blufke's Avatar
Default Re: phantom grip install (SpoolinLS)
what LSDs the dont cost an arm and a leg(quaiffe,etc) can go in an ls tranny?
Old Nov 14, 2002 | 12:50 AM
ninesecrx's Avatar
Default Re: phantom grip install (blufke)
People need to remember with a phantom grip, your still useing the stock diff. Stock diffs break... you pay for what you get.
By the way, sohc trans. are a little more tricky cause of the smaller case so if you can do it on that, you should be fine with the ls trans.
[Modified by ninesecrx, 9:51 AM 11/14/2002]
Old Nov 14, 2002 | 01:38 AM
wHOAlly's Avatar
Default Re: phantom grip install (ninesecrx)
if you looked at how the pg works u would realize how shitty a design and such a bad idea it is....i mean....would u shove a big wrench between your cam gears if u needed to lock them down?
Old Nov 14, 2002 | 03:54 AM
PWRVTEC's Avatar
Default Re: phantom grip install (AkumaY)
All I will say is Quafie and maybe....I broke my stock diff All Motor on drag radials on the street shifting to 3rd....So like ninesecrx said Stock diffs break....
Old Nov 14, 2002 | 05:06 AM
boomslang's Avatar
Default Re: phantom grip install (PWRVTEC)
The install isn't hard. It'd be great experience for you. The Phantom Grip is a peice of **** however.
Old Nov 14, 2002 | 05:26 AM
my96GSR's Avatar
Default Re: phantom grip install (Inlinefour)
Why is the phantom a piece? I was thinking of using one on our teams race car.
Old Nov 14, 2002 | 07:23 AM
boomslang's Avatar
Default Re: phantom grip install (my96GSR)
Check old posts man. There is a lot of info out there about them.
Old Nov 14, 2002 | 07:37 AM
Armed Ferret's Avatar
Look at the picture about 8 posts up
if you want your differential to look like that, i say go for the Phantom Grip!!!
If you want your differential to actually LAST, get a quaife or kaaz or type r.
Old Nov 14, 2002 | 11:18 AM
IntegD's Avatar
New User
Default Re: phantom grip install (zoomintegra)
I just recently had my Quaife installed in my gsr tranny. I have rebuilt a total of like 8 motors and like 5 swaps or so, so I am pretty mechanically inclined. I was a little scared to try it because I had never seen the inside of the casing except for what I read in the HELMs. I watched the acura techs do it and if I had to do another one I would just do it myself. Its not that hard, but I personally think its something you should watch the first time around, esecially if this is your daily driver.
Old Nov 14, 2002 | 12:15 PM
paulzy's Avatar
Default Re: phantom grip install (IntegD)
oh, and jsut so you know...if you are gonna R&R the ring gear, the threads are reveresed
Old Nov 14, 2002 | 01:49 PM
AR Fab's Avatar
Things to know when splitting the case......There are line up marks that make everything fit like a glove when you put it back together. It took reading the Honda manual and many hours fighting the dam thing before I got it right....Now I rebuild them in less than 30 min. Just installed a PG on a 96 D-series trans...three words....GRIND SPIDER GEARS.....Find a factory LSD/ it would be a better choice...
Howard
mcmmotorsports
10
Dec 24, 2013 08:48 AM
explorerx7
May 24, 2005 03:48 PM
Rod.
Sep 22, 2004 03:11 PM
TurboLude97
Sep 15, 2003 07:40 AM
Neptune
Dec 25, 2002 10:52 PM
