Launch Control
Old May 6, 2005 | 09:39 AM
KRTRACING's Avatar
Default Launch Control
there is a CRX that has a b16 in it. Every time he races i noticed that he has a launch control in his car. He gives it gas and it hits one RPM and stays there... Does anyone know how he does it or where to find the electronics to do this? Thanks...
Old May 6, 2005 | 09:57 AM
crazykid's Avatar
SEARCH.... https://honda-tech.com/zerosearch
BUT, you could try msd's website, mallory, hondata, and ems
Old May 6, 2005 | 10:12 AM
Pullig's Avatar
Default Re: (crazykid)
uberdata does it
Old May 6, 2005 | 11:00 AM
Bulldogg83's Avatar
Default Re: (Pullig)
Neptune does it as well.
Old May 6, 2005 | 12:22 PM
sleeperHatch's Avatar
Default Re: (Bulldogg83)
I use a toothbrush, a lighter, and 3 candles...that usually does it for me!!
j/k
its called a two step...i use the one made by MSD
Old May 6, 2005 | 12:36 PM
FormulaGSR's Avatar
Default Re: (sleeperHatch)
i made one using an MSD revlimiter hooked to the clutch switch on my buddies hatch. With the clutch in it wont rev past the set RPM(has a dial to set it). Since it was a part we salvaged off another car it was a free mod.
Old May 6, 2005 | 03:41 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">uberdata does it </TD></TR></TABLE>
Yeah, so does Crome. Its a simple routine. You simply tell the ECU that if there is no signal from the speed sensor then you want the rev limiter set at xxxx rpm.
Old May 6, 2005 | 09:33 PM
miller.91.HB's Avatar
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, so does Crome. Its a simple routine. You simply tell the ECU that if there is no signal from the speed sensor then you want the rev limiter set at xxxx rpm. </TD></TR></TABLE>
I just set mine up with crome..... love it!
Old May 7, 2005 | 12:56 AM
1750cc's Avatar
Default Re: (miller.91.HB)
i use hondata. works great.
Old May 7, 2005 | 08:36 AM
asilaydying1984's Avatar
Default Re: Launch Control (KRTRACING)
he is talking about me lol my ecu is chipped with uberdata you should have just asked me i would have told you.
Old May 7, 2005 | 09:16 AM
Johnny O A20 KIller's Avatar
If you have a MSD box you can use a 2 step box and hook it up to a switch.
Old May 7, 2005 | 10:37 AM
importdude2000's Avatar
i have 2step from msd
i heard its bad to 2step from hondata cuz it cuts fuel
Old May 7, 2005 | 12:33 PM
if you want launch control my friend will chip it for you, and burn you a chip he can also raise your rev limit whatever you want it him to do, but he is going to charge you
MidnightB16
Jan 24, 2009 01:00 PM
91lsturbocrx
Dec 7, 2008 06:51 PM
vectorsolid
Jun 11, 2008 11:51 AM
CLE
Sep 11, 2006 10:06 AM
rice is nice
Jun 30, 2005 01:46 PM
