Kill switch setup, will it work?
from what that looks like to me that it will just cut the battery off with the car will still run. am i correct? you need to runa wire from the alt back to the on side and wire from the off side to the fuse box
Now that the correct wiring path has been established, what gauge wiring should I run from the Alt to the switch and the switch to the fuse box\starter?
Once I know that I should be good to go.
Thanks for all the help guys.
I ran 2 aut (not sure on spelling) it was actually cheaper to go to catapillar and buy a 50 ft. welding lead 2 aut cable. It is very fine stranded and i think it was around $70. I had 2 cars to do so it was worth it.
The cable is very flexable also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportMotorSpec »</TD></TR><TR><TD CLASS="quote">I ran 2 aut (not sure on spelling) it was actually cheaper to go to catapillar and buy a 50 ft. welding lead 2 aut cable. It is very fine stranded and i think it was around $70. I had 2 cars to do so it was worth it.
The cable is very flexable also.</TD></TR></TABLE>
How many feet you think I would need for a 4 door? Did you run under the car or through the car?
I was thinking of maybe running the wires through the exhaust tunnel, covered by heat protectent tape. Good, not so good?
Another option to consider, If your battery is up front still or whatever the case.
You could do a Flaming River kill switch w/ A push pull cable, that runs from the rear bumper to the FR kill switch. This would just prevent running huge heavy leads back and forth. Looking much nicer also.
Checkout their website.
You would have to get the push pull cables from someone else.
You would use their lever switch.
Justa thought
Justa thought
tub_sephiroth
May 9, 2007 07:35 PM
