Jan FS Thread
B-series golden eagle main girdle comes with mainbolts and dowel brand new torque once to try it on... b18/b20/b16
$230 shipped and paypal fee included
Call or text for pictures 925-325-5005
Full-race Pro am 4" downpipe in great condition and comes with 4" SS flex pipe $375
[IMG]
[/IMG]
4 oem 14" stock steelies in great condition $100 pickup
[IMG]
[/IMG]
Custom 4" aluminum mandrel bend exhaust for EG with v-band connection and comes with clamp and vibrant race muffler. Pick up prefer $450
[IMG]
[/IMG]4 oem 14" stock steelies in great condition $100 pickup
[IMG]
[/IMG]Custom 4" aluminum mandrel bend exhaust for EG with v-band connection and comes with clamp and vibrant race muffler. Pick up prefer $450
Motec B-series setup. Ready to run. Everything is in mint condition.
Includes:
M800 (US spec) that has Advanced tuning, Lambda, 1mb logging enabled
Motec engine harness and cabin harness with Mil spec plug for firewall
Motec E888
ProDrag 4
Ignition harness with Mil spec plug for firewall
CBR coils
T1 coil hold down
Motec UTC
$8500 firm for everything!
Buyer flaked so it's back up for sale.
I also have the complete pinout for the harnesses, and original boxes that stuff came in from Motec. I will include a startup cal with the sale of the M800.
PM me with any info.
Chris
Includes:
Motec E888
ProDrag 4
CBR coils
T1 coil hold down
Motec UTC
Chris
PM for shipping quote. I'm located in BC Canada, and paypal verified.
Vented Valve Cover & Catch Can
- Rare Acura EL 1.6 valve cover, painted wrinkle black
- Tigged bungs
- Lines
- Tigged catch can w/ K&N filter
$300 + shipping
Russell Inline Fuel Filter
- -6 Male
- #650130
$33shipped
Autometer Tachometer w/Shift light
$90 + shipping
- Tigged bungs
- Lines
$300 + shipping
- -6 Male
- #650130
$33shipped
$90 + shipping
couple thing im looking to get rid of.
pm questions
all prices reflect shipped price to 48 CONUS ( this is because I hate when you wanna buy something and someone gives oyu a bullshit price to ship)
Everything I ship is USPS tracked this is because they are cheaper than UPS and fedex by as much as 50%
trades welcome looking for SFWD intercooler
skinny 4x100
PNP pr3 head
hondata CPR
G force harness
please note I am not machine shop.
if my post is confusing then please pm me or text me.
205 three 83 78 four 7
b18B crankshaft was pulled form a running motor. all journals look good.
INCLUDED IS THE GEAR NUT AND KEY TO INSTALL THE CRANK PULLEY. THIS IS NOT ALWAYS THE CASE WHEN YOU BUY OTHER CRANKSHAFTS THEN YOU ARE SEARCHING FOR PARTS. $200 SHIPPED WITH ALL LISTED
ITR HARMONIC BALLANCER $40 WITH PURCHASE $60 WITHOUT
b18C1 BARE BLOCK (this mean the block and the caps and gridle with oem bolts manin seal plate) this motor is stock bore or so im told but looks as such and measures right. I also have all the bolts for the attachments like water pump oil pump and most of the other stuff. this is so you don't have to spend $80 at Honda to get the bolts to put your block together.
could use a hone/line hone deck surface looks good
$300 shipped for all above listed
$430 shipped all above plus ( water pump oil pump oil pan windage tary oil pick up water tube and thermo housing pcv box ITR crank pulley oil pan. this would be a great set up!!!) pretty much everything you need except rods and pistons. all the bolts
PR3 cam gears painted black $20 shipped
pcv box $25 shipped
P72 oil pan small dent will come with gasket over all good condition $70 shipped
b18C windage tray and oil pick up. excellent condition $50 shipped
used oil pump b18C it works $40 shipped
b18c water pump it works spins free $20
motor mounts 160 shipped
ITR crank pully harmonic $60 shipped 40 with crank
pm questions
skinny 4x100
PNP pr3 head
hondata CPR
G force harness
pcv box $25 shipped
Up for sale 15x10" start8 with double bead lock it comes with 26"x10" MH slicks 6" back spacing $700 it comes with no center u can buy which ever brand u would like plus shipping and PayPal fees any ?? Text me at 978-995-2377
FJO injector driver $100 ship
Billet Wilson 90mm Throttlebody with throttle bracket and vangen vibrant clamp already weld it to it tb it's like new only use it for like 10 pass $350 ship
PTE precision 1500hp 3.5" inlet and outlet it's coat it with black the tank and the intercooler for no condensation that pic it was before it get coat it black it comes with rule inside water pump and lines
few parts left from my part out for sale if interested text 973-420-0348 located in north jersey prices include shipping but NOT paypal fees!
DSS stage 3.9 axles with hubs and extended studs $750 pick-up only
T1 catch can with lines and valvecover powder coated black with skunk 2 billet oil cap only thing missing is fitting for back of the block (ipg sells them) $400 shipped
AVID EK solid b-series mounts with ek b-series t-bracket.......SOLD
Golden Eagle b-series scatter shield........SOLD
Honda b-series starter.....SOLD
Clutch Masters b-series 725 twin disk ....SOLD
prices are FIRM but will work out a deal if you buy more than one part
Sheepey Mini-Outlaw forward facing turbo kit
Price: $1900 firm (shipping and paypal extra)
(will not part)
Description: Brand new never used Sheepey Mini-Outlaw Forward facing turbo kit
Comes Manifold T4 flange, intercooler, down pipe (out the hood), dump tube, cold side pipe (will need to add piping to connect to TB)
60mm Waste gate flange on manifold
(will not part)
For Sale 2006 Honda Civic Si Rolling Chassis...Setup for the All Motor Class currently but could easily be a Turbo Car if you wanted.
The car is 2090 lbs and no ballast added and a 155lb driver.
With still 50-75 more lbs that could be still be removed from the chassis.
- Clean Title Black 2006 Civic Si Chassis
- 5 Point roll bar (By Mazworx)
- Sunroof plug
- Catch pan
- Kirkey seat
- RCI camlock harness
- Cnc staging brake
- Blox front control arm with spherical bearings
- Steel braided brake lines throughout
- Quick disconnect steering wheel setup
- Switch panel in middle center console (no factory wiring left, switch panel controls it all)
- Hasport mounts
- Progress coilovers (Off the shelf)
- DriveShaft Shop Level 2.9 Axles
- Skunk2 rear camber kit
- Weld 13x9 Aluma Star Front wheels
- Weld 15x3.5 Aluma Star Rear wheels
- Fastbrakes Wilwood Single Piston Front Brake Kit
- Brand new OEM front and rear bumpers (not painted or installed but included)
Car with those parts listed - $7200
Add-on’s
- Fuel System consisting of, Custom Front Mount 1 gallon fuel cell with Weldon 2015 fuel pump, AN Lines, Filters, FPR, etc - $875
- Fluidyne Radiator Setup with -12an Lines, Electric Water Pump, etc - $550
- Antigravity 16v Battery with Charger - $475
- ASP under car exit header - $1000
Feel free to email us at Sales@IPGparts.com for any additional pictures or information.
Everything is brand new aside from long block.
Arias pistons for k24
part # 3330565
87.5mm bore
14.5:1 compression
$470
Eagle rods
k24a length
small end already machined to fit wrist pins
$330
k24a1 longblock
PPA head (sought after for having same ports as PRB head)
Separated head from block, otherwise it's complete.
$600
part # 3330565
87.5mm bore
14.5:1 compression
$470
Eagle rods
k24a length
$330
k24a1 longblock
$600
NLR AMS1000 boost controller- comes with everything you need. Also comes with c02 bottles and cage mount $800 shipped
True street chassis- Moly cage, suspension,kirkey, chute mount, fuel cell, traction/weight bar
$3200.
Weld magnum fronts 13x9 6'' back spacing. screwed inside and out, powder coated gloss black lips with matte centers $750 FIRM
Spingwerks skinnies powdercoated gloss black with m&h tires- $700
Hasport solid billet motor mounts- $300
custom T4 topmount, singlescroll with 44 mm flange- $500
Tial 44mm gate, black with 10lb spring- $200
B16 head-ported, polished. Supertech everything~springs with k series retainers, ferrea keeprs, incolnel exhaust valves, good guides and seals -$1000
BC stage 3 all motor cams, "the big ones" with adjustable cam gears- $400
84.5mm AEBS sleeved GSR block, O-ringed, CP 9.1 pistons with upgraded pins, eagle rods with 625 bolt upgrade, ACL race bearings, ATI super damper, 1 set of golden eagle head studs and 1 set of A1 headstuds, assembled by inline pro. $3000
Might have some more stuff laying around
call or text for more pictures/info 540-270-9843
Located in northern Virginia
$3200.
Whats up guys. have some barely use parts for sale. the 105 crank literally only saw dyno time. we had a crank get messed up from the flywheel bolts coming lose and put this one it and at the same time 4 piston was building alexs 106 stroke engine. that 105 motor never saw the track and everything was sold except for the crank.
the clutch was put into the car brand new before WCF 2013 and the car was having shifting issues on the dyno and we couldnt figure it out. we changed the clutch thinking it was the problem and it wasnt. turned out the shifter mechanism on the trans was broken. clutch has like 5 pulls on it.
1000 shipped for the clutch
1500 shipped for the crank
I have some stuff for sale. Prices are OR BEST OFFER. I am located in North Austin, Texas
These parts are brand new
Edelbrock victor x manifold for b16/typeR $275
Innovative solid mounts for B to EG Chassis $275
Tial BOV 50mm $240
Golden eagle vtec conversion kit $150
Full Race traction bar setup $280
GSR brembo blank front and rear rotors with ebc green stuff front pads and ebc ultimax in the rear $200
Strada 3 piece open front end for EG $800
These Parts are used
Skunk2 Pro series cam gears $200
FCS 5 gallon tank $350 (PENDING SALE)
Would like to sell turbo, wastegates and manifold with up pipes as a kit $2000 (PENDING SALE)
Borg warner twin scroll S372
Two Tial 44mm wastegates
AFI Forward facing manifold with 4 inch up pipe and waste gate up pipes
Tial BOV 50mm $240
Fs: brand new precision 6766 its t4 and ball bearing 1.15 divided exhaust housing one year warranty 1600 obo
B series forward facing divided manifold dual 44 gates 899
Can do a package deal 2100 picked up or 2150 shipped located in maryland any questions pm or text me 2402161030 thanks
Means of contact: 804-337-8376
Comp Clutch Twin Disc with all hardware. Like 10 dyno pulls (1 session) on it. Looks brand new -$800
Brand New KMS Bronze Valve Guides - $35
Brand New Crower Stage 3 Turbo/NA Cams Part no. 63403-2 - $375
Brand New Crower 1mm Oversize Intake Valves and .5 Over Exhaust Valves - $275
