Intake Air temperature
Old Sep 19, 2012 | 12:28 PM
Steeve_Civic's Avatar
Default Intake Air temperature
How do you cold your Intake Air temperature between each Run?
Some guys use these big Fan?
Is it really useful?
What is your intake temperature?
Old Sep 19, 2012 | 01:27 PM
tepid1's Avatar
Default Re: Intake Air temperature
I add ice, but I'm sure that doesn't help you. I have yet to see charge temp over 88deg F even when it's 90+ outside at full boost.
Old Sep 19, 2012 | 01:31 PM
Natural Aspirations's Avatar
FCS Supercooler?
http://www.fcsfab.com/products.html
Old Sep 19, 2012 | 03:57 PM
xenocron's Avatar
Those fans just help heat soak a little, they don't really change the temperature of the air going into your motor as it goes down the track
Old Sep 19, 2012 | 04:00 PM
onefstek's Avatar
Electric water pump and leave it on in the pits. You would have to have a switch for the fan to stay on as well.
Stefan
Old Sep 20, 2012 | 09:06 AM
ralph11sec's Avatar
a2w ic and put ice every run
getting high 50s F @ idle. when its 90 outside. iat is in manifold.
Old Sep 20, 2012 | 11:29 AM
Thank you for your advices
I Understand that a watercooler with Ice in the tank will be the best but I use an Intercooler and looking for a solution to cold my air temp.
Old Sep 20, 2012 | 12:30 PM
Compressed CO2 is cheap if you want to cool between runs, nitrous works better spraying on the intercooler while racing.
Old Sep 20, 2012 | 01:27 PM
B18c1turboedEK's Avatar
If your asking about IATs then why you posting a pic with a car and fans on it? Kinda confusing post.
Old Sep 20, 2012 | 02:25 PM
rudebwoy's Avatar
water/methanol injection
Old Sep 21, 2012 | 10:56 PM
Just wanted to know the way to reduce Heat in pits and during the run.
I've seen these fans sometimes in pits.
Old Sep 22, 2012 | 01:15 AM
fo0's Avatar
fo0
what is this guy spraying on his intercooler at 11:07 in this video? http://vimeo.com/7617404
Old Sep 25, 2012 | 12:28 PM
N2O but quite expensive.
Should be useful!
Old Sep 25, 2012 | 02:07 PM
rudebwoy's Avatar
you can also use CO2 I used it before when I had a ntercooler sprayer. and I set it up on a switch that I could activate anytime I feel.
ama11
Sep 6, 2010 10:21 AM
KStuned
Jul 28, 2004 08:01 PM
Arsenal
Dec 7, 2003 10:43 AM
Razor
Jan 26, 2002 10:05 AM
