Ignition is it worth it?
Old Mar 24, 2005 | 01:25 PM
kblus711's Avatar
Default Ignition is it worth it?
Ok, I have a 94 B18c1 motor w/ I/h/testpipe/E, IM, TB, FPR, Stage 1 cams. I am running NGK wires and Denso Iridium plugs. I am about to put my hondata in and have it tuned. Would it be in my best interest to Get the MSD blaster Coil, cap and rotor prior to having it tuned?
Old Mar 24, 2005 | 02:56 PM
skunked's Avatar
Default Re: Ignition is it worth it? (kblus711)
you don't need unless you want to run a 2step.
Old Mar 24, 2005 | 02:58 PM
ndogg's Avatar
may as well do it before you tune as oposed to after. i'm not sure how much it will benifit your mild setup though. i'm not into the all motor thing, i don't know when you guys normally upgrade. you can modify the stock cap if you don't want to spend the cash on a msd cap.
Old Mar 24, 2005 | 03:13 PM
ndogg's Avatar
Default Re: Ignition is it worth it? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">you don't need unless you want to run a 2step.</TD></TR></TABLE>
i don't think you can run an MSD 2-step off the coil, you need the box. and the box is ****. if you want a 2-step, get neptune/hondata/uberdata/crome.
-nate
Old Mar 24, 2005 | 03:21 PM
skunked's Avatar
Default Re: Ignition is it worth it? (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
-nate</TD></TR></TABLE>
right you need to run a 6AL, soft touch etc. Upgrading the coil to an MSD coil on a mild motor is not beneficial. The box is **** huh? First time I have heard that about an msd box.
Old Mar 24, 2005 | 03:39 PM
ndogg's Avatar
i've never used one on my car but, of all the cars i tuned, they did nothing but make things go wrong. so maybee they aren't ****, but not worth it on any mild setup.
Old Mar 24, 2005 | 03:47 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">i've never used one on my car but, of all the cars i tuned, they did nothing but make things go wrong. so maybee they aren't ****, but not worth it on any mild setup.</TD></TR></TABLE>
I think the biggest problem is the people installing them poorly. All it takes is one bad connection and it's not gonna work at all.
Old Mar 24, 2005 | 04:45 PM
2k.civic.si's Avatar
ive installed many msd systems...not one has had a problem....most have been in use on daily driven cars for years....my msd sci-l has been in use since 01 and its now 05....hasnt skiped a beat.....are malibu boat also has a msd system on the mercruiser 350 engine and hasnt failed once in years....the systems i have seen with problems that i got to fix was due to the most screwed up installs ive ever seen...
Old Mar 24, 2005 | 05:58 PM
tony1's Avatar
MSD is one of the most unreliable ignition systems you can buy, but fortunately for MSD, there aren't many other options. Show me a racer who says MSD is good quality stuff, most run it cause they don't know of a better option. If you want a good quality ignition box, get an M&W box.
Old Mar 24, 2005 | 06:43 PM
skunked's Avatar
Default Re: Ignition is it worth it? (tony1)
M&W huh? I like it already since those are my initials.
Found it: http://www.mwignitions.com/main.html
Old Mar 24, 2005 | 07:24 PM
tony1's Avatar
Old Mar 24, 2005 | 07:29 PM
Big_Mike's Avatar
Default Re: Ignition is it worth it? (2k.civic.si)
I have been looking for a way for years to get all MSD **** out of my car, I finally found a way thanks to Tony!! I used 2 MSD Digital-6 boxes each race season, and had to constantly get them fixed from MSD.
Old Mar 25, 2005 | 05:46 AM
CHEETAH's Avatar
Default Re: Ignition is it worth it? (Big_Mike)
what specific kind of problems are you guys having with MSD boxes ?
Tony, what problems do MSD boxes give ?
Greg
Old Mar 25, 2005 | 09:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Ignition is it worth it? (CHEETAH)
MSD are just junk. Walk around in the pits and you'll see at least one person looking for an ignition box or coil. M&W are the ****. If you have an EMS that has 4 ignition outputs and you want to run COP then Autronic CDI or Motec shine.
Old Mar 25, 2005 | 12:17 PM
kblus711's Avatar
I thought i could run the external coil just for a better spark... Why would there even be a problem if the install was done correctly?
thanks for the input so far keep it coming.
Old Mar 25, 2005 | 01:20 PM
skunked's Avatar
The stock coil is fine.
Old Mar 26, 2005 | 09:54 AM
kblus711's Avatar
thanks guys i will let u know what i go with and if it helps anything at all.
Old Mar 26, 2005 | 02:47 PM
BokChoy's Avatar
is it worth upgrading your ignition if you are going to run a stock coil and cap? And are crane ignitions ****?
Old Mar 26, 2005 | 03:11 PM
fast is fun's Avatar
MSD can,t be that bad all the top fuel, funny car, pro stock +++ use it
Old Mar 26, 2005 | 03:12 PM
Default Re: Ignition is it worth it? (fast is fun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast is fun &raquo;</TD></TR><TR><TD CLASS="quote"> MSD can,t be that bad all the top fuel, funny car, pro stock +++ use it</TD></TR></TABLE>
that or mallory....from what ive seen the top fuel people either use msd or mallory.... that outta tell you something
Old Mar 26, 2005 | 03:14 PM
more MSD
Old Mar 26, 2005 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast is fun &raquo;</TD></TR><TR><TD CLASS="quote"> more MSD</TD></TR></TABLE>
yup
Old Mar 26, 2005 | 03:39 PM
Arturbo's Avatar
Better than steak
25 Year Member
They all run carburators, should we run them too? Dont get me wrong MDS gets teh job done but how many times have you heard of people having problems with them. Alot! On my digital 6 we have to run a small ignition gap like .020, on a CDI from motech or autronic you run anywhere from .030-.035 ish. That should tell you something.
Old Mar 26, 2005 | 03:44 PM
Default Re: Ignition is it worth it? (Arturbo)
more opinions....you know what they say about opinions....and they run carbs your point?....since when did the ignition systems have anything to do with how the air/fuel gets in the cylinder
NSCA event winners of 04 all use msd...just one example...
Event winners include Marc Dantoni in Outlaw Street, Kenny Bennett in Super Street, Tim Davis in Hot Street, (all MSD users mind you) and many more.
Old Mar 27, 2005 | 07:34 AM
tony1's Avatar
Top fuel and funny car run mags, that's a different ballgame, and pro stock doesn't have the electronics to run individual coils. Let's take a look up into the higher forms of racing, since drag racing is usually pretty far behind them. Formula 1, IRL, Cart, etc, you think you'd find an MSD anywhere near any of those cars?
Forget about that altogether, i've run them all, from msd 6-10, motec, m&w, and autronic. The msd is the last one on my list of parts to buy. I don't expect anyone to go out and use what I say, but when you've seen results with your own eyes it's hard to believe otherwise.
