how to launch?
Old Jun 6, 2003 | 09:48 PM
JDM GSRRACER's Avatar
Default how to launch?
when we do the staging then while we are waiting for the light to turn green after the two staging lights, I want to REV IT UP TO LIKE 5000 Or so but the problem is how do i keep my car in place it seems to move a little, what do you guys do?
Old Jun 6, 2003 | 11:23 PM
J2turbo21's Avatar
Default Re: how to launch? (JDM GSRRACER)
E-brake bro use it.Just put it in gear,pull the upbrake but make sure you hold the button so you can release it easier.
Old Jun 6, 2003 | 11:47 PM
10seconds's Avatar
Honda-Tech User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM GSRRACER &raquo;</TD></TR><TR><TD CLASS="quote">when we do the staging then while we are waiting for the light to turn green after the two staging lights, I want to REV IT UP TO LIKE 5000 Or so but the problem is how do i keep my car in place it seems to move a little, what do you guys do?</TD></TR></TABLE>
if your car is moving at a local track then that is one shitty track
steve
Old Jun 7, 2003 | 11:37 AM
b19coupe's Avatar
My car does not move at Palmdale, so no E-brake. At Fontana, I redlighted a couple of times because my car moved, so the e-brake trick is a must there, for me anyway.
Old Jun 7, 2003 | 01:54 PM
CHRIS 1.8's Avatar
Default Re: how to launch? (10seconds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seconds &raquo;</TD></TR><TR><TD CLASS="quote">
steve</TD></TR></TABLE>
If b19coupe's car does not move at Palmdale, then I guess Palmdale must be a good track.
Old Jun 7, 2003 | 04:22 PM
b19coupe's Avatar
Default Re: how to launch? (CHRIS 1.8)
LACR is a shitty track.LACR is in Californie. Ergo: all tracks in California are shitty. One does not follow the other. Just like saying that if a car does not move when staging, the track must be good. The two tracks mentioned were merely used to illustrate that you need to use the e-brake trick at some tracks, and not at other tracks. If you do not need to use the e-brake trick, it's better not to, less chance that you will forget and leave it on during your run. It's all good.
5poonhatch
Jul 24, 2006 10:40 PM
ATX45
13
Jun 11, 2006 07:24 AM
DynastyRacer22
Sep 9, 2005 02:31 PM
HatchEh2
Nov 1, 2004 09:17 AM
Reddog
Mar 22, 2004 04:00 PM
