help with cooling system beeing pressurized
Old Jun 12, 2011 | 02:01 PM
YAGGA_YA's Avatar
Default help with cooling system beeing pressurized
i got a ls/vtec sleeved block 84bore .30 head gasket running 20psi.
changed thermostat twice
ugraded rad
its not overheating it jus pushing water out the rad cap
bleed the system more than once.
help!!!
Old Jun 12, 2011 | 02:27 PM
2k.civic.si's Avatar
Default Re: help with cooling system beeing pressurized
The only other thing it could be is a bad radiator cap. If its not the radiator cap then its the headgasket.
Old Jun 12, 2011 | 03:35 PM
civickiller's Avatar
I had water bubbling from cap with no overheating, new cap fixed it
Old Jun 12, 2011 | 03:59 PM
MR.johnson's Avatar
head gasket, IM gasket. or bad cap.
Old Jun 12, 2011 | 05:29 PM
JustOneOrTwoPosts's Avatar
I call a bad radiator cap
Old Jun 12, 2011 | 10:54 PM
YAGGA_YA's Avatar
Jus Installed a new mishimoto Rad an cap a few weeks back
Old Jun 12, 2011 | 11:20 PM
uglyasscivic's Avatar
do a leakdown or coolant pressure test to check the head gasket.
Are you using a lsvtec dowel pins or was the head drilled or machined for the lsvtec? If the head was done wrong you will see some gasket sealing issues over time.
Old Jun 13, 2011 | 03:34 PM
DRAGLS's Avatar
Run a stant 24lb cap. That's what I had to get to prevent boilover.
Old Jun 13, 2011 | 04:58 PM
YAGGA_YA's Avatar
i used the dowels in the GE kit.
Old Jun 13, 2011 | 05:00 PM
YAGGA_YA's Avatar
who sell's them?
cause mine came with a 19psi cap
Old Jun 13, 2011 | 06:26 PM
If your using a new cap and its 19psi then its most definetly a headgasket problem.
Old Jun 13, 2011 | 08:39 PM
DeLucia's Avatar
Yeh im running a 16psi cap with no problems
Old Jun 14, 2011 | 03:52 AM
Boosted_B_Series's Avatar
What did you tq your headstuds down to?
Old Jun 14, 2011 | 12:27 PM
YAGGA_YA's Avatar
I was told to torque then at 84lb cause I had used my old head studs from another motor that had been torques like 3times before.
Old Jun 15, 2011 | 05:31 AM
JJsMotorsports's Avatar
We had similar Problem it was a dropped sleeve.
Old Jun 15, 2011 | 05:59 AM
twkdCD595's Avatar
From my experience with something similar, its a headgasket I would bet and given you have a new cap on it which would be the other culprit I would have guessed.
Old Jun 15, 2011 | 12:04 PM
v.i.gsr's Avatar
Bingo, hit it right on the head.. I'll bet that's the problem..
osnimoh
10
Sep 25, 2013 12:22 PM
thewrai6th
Feb 8, 2013 02:11 PM
panchlow
Dec 18, 2010 11:43 AM
bigizsosexy
May 5, 2006 12:14 PM
BoostedD15B7
Jul 28, 2002 07:14 PM
