b16 cx at the track
Old Jun 12, 2011 | 09:45 AM
Eric724's Avatar
Default b16 cx at the track
well i took the civic to the track yesterday i have a 92 civic cx with a jdm b16 it has a skunk2 exhaust and a obx intake manifold and a act stage 3 clutch other then that its all stock
first run launched at 3500rpm
60ft 2.48
1/4 15.39
1/4mph 89.9
second run launch at 6500rpm
60ft 2.32
1/4 15.13
1/4mph 90.3
third run launched at 7000rpm
60ft 2.61
1/4 15.61
1/4 91.3
here is a couple pics of the car at the track
Old Jun 12, 2011 | 10:19 AM
Eric724's Avatar
Default Re: b16 cx at the track
Old Jun 12, 2011 | 10:38 AM
Eric724's Avatar
i read that a stock b16 only runs anywhere from a low 15 to a high 14 so get your facts straight
Old Jun 12, 2011 | 12:50 PM
apexi_rsx's Avatar
as u see the b16 is gutless many b18b nonvtec swaps run low 15's as well. nice runs u shouldn't launch over 3k unless u have slicks or drag radials.
Old Jun 12, 2011 | 12:58 PM
em 1.0's Avatar
did you beat that camaro?! and launching at those rpms are going to slow you down...spinning the tires doesnt make your car faster
Old Jun 12, 2011 | 04:52 PM
Eric724's Avatar
my first run i launched at 3500rpm and it wheel hopped really bad but when i launched at
6500 it still wheel hopped but not as bad plus i was running 35psi in my front tires anyone have any advice for the next time i go THANKS
Old Jun 12, 2011 | 04:54 PM
Eric724's Avatar
i will try to upload the video of my second run where i launched at 6500 no i didn't beat the camero
Old Jun 12, 2011 | 04:58 PM
MR.johnson's Avatar
cool story bro.
Old Jun 12, 2011 | 06:16 PM
turbojdmhatch's Avatar
idk drag radials might help but you would probably still run a 15 second quarter mile, suspension helps also
Old Jun 12, 2011 | 07:40 PM
civickiller's Avatar
my friends eg b16 hatch on street tires went 14.6 so get your facts straight.
My ef ls hatch went 15.0 on street tires
Old Jun 13, 2011 | 12:16 AM
SonicRacing1's Avatar
Remove ur headlight im sure it will help an its free
Old Jun 13, 2011 | 02:05 PM
Eric724's Avatar
HERE IS THE VIDEO
http://s558.photobucket.com/albums/s...pyofMOV01C.mp4
Old Jun 14, 2011 | 08:50 PM
jsw_1986's Avatar
Lower your tire pressure to around 18-20psi I'd try slipping the clutch rather than dumping it. 2nd gear burnout to heat up the tires good. good investment would be some drag radials. should be good for some mid 14's if you can get it to hook. Lots of seat time and you'll get it dialed in.
Old Jun 15, 2011 | 02:00 PM
Eric724's Avatar
thanks
Old Jun 15, 2011 | 02:55 PM
Eric724's Avatar
what size drag radials should i use and what brand
Old Jun 15, 2011 | 06:18 PM
m!ke's Avatar
14 inch bfg drag radials. 205 50 14. they fit on steelies so its a nice cheap track tire that you can drive to the track on but since you can easily get a set of steelies you wont have to worry about putting them on your regular rims. also that size tire works out perfectly for a stock b16 trans. i trapped 98 mph in my b16 with them and i finished almost at the end of 4th gear.
mubeenbil
13
Mar 25, 2010 02:25 PM
92-LS-Civic
Aug 26, 2004 10:19 AM
jlh81
Apr 30, 2004 11:40 PM
PotatoePAPA
Jun 1, 2003 09:57 PM
FASTEG
49
Apr 3, 2003 09:33 AM
