head studs
Old Jan 25, 2004 | 01:45 PM
turbo96wr's Avatar
Default head studs
was up who would like a head stud that would be better then arp, aebs is a good stud i use them and also am product sponsor by ben and paulus, but the stud i am talking about is made by A-1 technologies and they are the makers of the aebs stud and also for nascar and top fuel nhra, the next material in line is called H-11 which would be a stud that you could use over again and you would have your total torque spec and would only be using 80% of the stud strengh. the next material is called MP (multiphase) which would be an overkill for the honda block. they will only make it for me if i order 10 set's.
Old Jan 25, 2004 | 03:45 PM
wHOAlly's Avatar
Default Re: head studs (turbo96wr)
all about cost
Old Jan 25, 2004 | 05:02 PM
MAX_CFM's Avatar
What NASCAR teams use them? just curious
Old Jan 25, 2004 | 05:39 PM
turbo96wr's Avatar
Default Re: head studs (MAX_CFM)
i could not tell you what team but they also make for CART and IRL they have also team up with LISI AEROSPACE one of the leading company's in aerospace. when i spoke with the main tech he also said that one of the teams that used H-11 was doug kalitta and warren johnson. the H-11 material is more then enough for a honda block they know about the threads in the honda block and the clamp force would not pull the threads, but he assured me that it would be hard to lift the head those of us with high hp.
Old Jan 25, 2004 | 07:39 PM
MAX_CFM's Avatar
I always just change to 1/2 "studs
Old Jan 25, 2004 | 08:04 PM
Suprdave's Avatar
You run 1\2" Studs in Hondas?
Old Jan 25, 2004 | 08:46 PM
NFJohn's Avatar
Default Re: head studs (Suprdave)
we always used to run 1/2 studs in our motors when I worked for Venom. the is plenty of room to do it. At least we never had a problem
Old Jan 26, 2004 | 03:39 AM
turbo96wr's Avatar
Default Re: head studs (NFJohn)
with these studs there is no need for 1/2 in. they will be same dia. as the aebs stud and will work better then 1/2 in.
Old Jan 26, 2004 | 03:50 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo96wr &raquo;</TD></TR><TR><TD CLASS="quote">with these studs there is no need for 1/2 in. they will be same dia. as the aebs stud and will work better then 1/2 in.</TD></TR></TABLE>
What will you torqe these @ ?
Old Jan 26, 2004 | 05:03 AM
turbo96wr's Avatar
75 ft. lbs
Old Jan 26, 2004 | 07:22 AM
MAX_CFM's Avatar
Ok kewl Il look into them but for the 50 + psi boosted engine il stick the the 1/2 arp studs cant beat a 100 ftlbs and some o-ring action
Old Jan 26, 2004 | 10:31 AM
Suprdave's Avatar
Part # of studs in question? PM me please...
Old Jan 26, 2004 | 08:50 PM
Arturbo's Avatar
Better than steak
25 Year Member
I know of this company and they do make some really nice head studs.
art
Old Jan 26, 2004 | 10:13 PM
dmotoguy's Avatar
Default Re: head studs (Arturbo)
any love for the k-series?
Old Jan 27, 2004 | 08:21 AM
Suprdave's Avatar
Default Re: head studs (dmotoguy)
You can get any custom stud made...just costs $.
Old Jan 27, 2004 | 10:34 AM
RacerStev's Avatar
They also supply GM with these studs on the Ecotech. I just switched to
them for my Mopar.
On mine the studs are 11mm, I think the same as Honda use's. The 11mm's have the same tensile strangh as a normal 1/2" stud, but fit w/o machineing the head and the block. VERY pricey though!!
Old Jan 27, 2004 | 01:28 PM
turbo96wr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Part # of studs in question? PM me please...</TD></TR></TABLE>
there is no part# we have to get together and find 10 racers that would like to have them made (b18c) and put in the order it will make life easier on all of us,*** Racing uses them on mike crawfords neon.
call me at 254-539-6693 deepstage motorsports
black0hatch
Honda CR-V & Element
Aug 30, 2012 01:29 PM
hYbRid_Eg6
Jan 26, 2012 10:00 PM
1990_integra_DA9
May 19, 2008 04:57 PM
kabaroo
10
May 21, 2005 10:41 AM
clsmooth
Aug 24, 2003 06:47 PM
