Got a Question?
Old May 18, 2008 | 10:06 PM
S_BUILT775's Avatar
Default Got a Question?
Ok heres the deal
91 Crx
B18 Bottom (stock internals)
B16 Head (mild Port job)
T3O4E A/R .50 Turbo
22x8x13 M/H
I pulled a 12.9 @ 115 on 22x8x13 M/H on 10 psi 2.2 60ft....
The Cars on 10 psi of boost Rc 550cc injectors... Widebands readin 11.8-12.1...
An im launchin @ 4,800 rpms on a 2 step...
What do i need to do to pull a better time an a better 60ft?
Old May 18, 2008 | 10:56 PM
RedneckRicer's Avatar
Practice practice practice.
Play with your Launching RPMS start at 5500 and go up til you find your sweet spot.
PRELOAD is your friend
is the car actually tuned?
Old May 19, 2008 | 08:46 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Got a Question? (S_BUILT775)
why the 2.2 short?
did it bog or spin?
if it bogged, raise the 2 step.
if it spun, lower tire pressure and mess with launch till you find the sweet spot as said above.
Old May 19, 2008 | 11:12 AM
S_BUILT775's Avatar
Default Re: (RedneckRicer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer &raquo;</TD></TR><TR><TD CLASS="quote">Practice practice practice.
is the car actually tuned?</TD></TR></TABLE>
The car is tuned of a VAFC hack for right now... Just tuned off the wideband...
The car really doesnt bog off the line.. Just spin's like a mo fo... I had the tire pressue at 12 lbs the first pass then lowered it to 10 lbs an got a 1.9 60ft but went 13.2 @ 113....
I think i need to practide on preloding the car like you said i think it will help alot... An maybe play around with the 2 step alittle more...
I Appreciate the advice alot... Thanks...
Old May 19, 2008 | 11:22 AM
VAFC hack is not tuned. you are not actually controlling the timing and the Fuel. you are just making minor adjustments to fuel if that. not good enough. IMO
Diller bob
Sep 5, 2007 02:53 PM
beatthisspeed69
17
Jul 19, 2006 08:21 PM
22psicrx
Feb 15, 2006 11:22 PM
slotec
Aug 30, 2005 09:37 AM
jdm.ej
Jun 23, 2004 11:10 PM
