Car tuned at 8 psi can I turn up to 10 and be safe?
got my car tuned the other day by a buddy of mine using uberdata and a wideband and all on 8 psi, is it safe for me to run 10 psi on it and be ok?
Re: Car tuned at 8 psi can I turn up to 10 and be safe? (PrecisionH23a)
i did ... tuned it really safe at 8psi, then i cranked it up to about 10, been fine for about a month now
Re: Car tuned at 8 psi can I turn up to 10 and be safe? (MIKE JONES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE JONES »</TD></TR><TR><TD CLASS="quote">i did ... tuned it really safe at 8psi, then i cranked it up to about 10, been fine for about a month now </TD></TR></TABLE>
question is... will u be the "holy **** look at how small the pieces of my piston are" thread in another month?
Re: Car tuned at 8 psi can I turn up to 10 and be safe? (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">
question is... will u be the "holy **** look at how small the pieces of my piston are" thread in another month?</TD></TR></TABLE>
yea idk. the afr is still pretty rich. timing is on the conservative side. havent checked the plugs in a while, maybe do that tomorrow.
edit: cant find anybody around here to do a good chrome tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE JONES »</TD></TR><TR><TD CLASS="quote">yea idk. the afr is still pretty rich. timing is on the conservative side. havent checked the plugs in a while, maybe do that tomorrow.
edit: cant find anybody around here to do a good chrome tune </TD></TR></TABLE>
good god!! go check the plugs now! haha... i just started my build on friday, had an oil leak, it only idled for 2 minutes and 29 sec (logged on hondata haha) and i ve already checked the plugs like a million times... im so paranoid. now the damn ecu is fried. **** the cn2!!!!
You are best off tuning further than you will need when you get together with your friend. That way if you get a spike or want to turn it up for the track you will be able to without picking up your motor in a coffee can.
Modified by Cray91 at 1:59 AM 8/30/2005
In-N-Out Burger
Re: (Cray91)
The key is to tune for MAX boost (ie: 30psi). Then you can run anything under your max boost setting using a boost controller. The ecu will use the same map, but adjust according to your setting.
Does that sound right?
Re: (NightRider-gsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">The key is to tune for MAX boost (ie: 30psi). Then you can run anything under your max boost setting using a boost controller. The ecu will use the same map, but adjust according to your setting.
Does that sound right? </TD></TR></TABLE>
yup
yup
Re: (MIKE JONES)
On a relative note, once I put my 3" inch exhaust on my setup started getting boost creep from 7psi all the way up to 11psi. I took it to my tuner and he said everything was fine and that it was still running on the rich side.
Re: (Rod.)
to answer your question more accurately, it depends on if your tuner modified the tables above 8psi. if he didnt go over them and the lines are all fd up and intersecting, then dont do it.
ask your tuner, not us. its that simple.
NO.
NO.
Re: Car tuned at 8 psi can I turn up to 10 and be safe? (tuoniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">to answer your question more accurately, it depends on if your tuner modified the tables above 8psi. if he didnt go over them and the lines are all fd up and intersecting, then dont do it.
ask your tuner, not us. its that simple.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuoniz »</TD></TR><TR><TD CLASS="quote">
NO. </TD></TR></TABLE>
Obviosly my tuner modified the tables past what we tuned for, whats the problem?
Obviosly my tuner modified the tables past what we tuned for, whats the problem? </TD></TR></TABLE>
Just because your t00ner did it doesn't mean this kids tuner did. That's the problem. Also, ignition tables do come into play... not just fueling.
