Eliminating Vtec Solenoid?
Old 12-14-2012, 06:35 PM
ceearexx's Avatar
Default Eliminating Vtec Solenoid?
I was looking at Chris Millers NRG tech civic hatch and i noticed he had no Vtec solenoid? Can someone explain this to me if they know?
I noticed he said he has custom cams and modified rock arms. Does that have something to do with it?
Old 12-14-2012, 06:46 PM
MrParks's Avatar
Default Re: Eliminating Vtec Solenoid?
http://webcamshafts.com
they are pro series cams from web. they are what we run as well as many others
Old 12-14-2012, 06:58 PM
boostedh22a's Avatar
No VTEC?? No way!!
Old 12-14-2012, 10:59 PM
Steeve_Civic's Avatar
Interested
Old 12-15-2012, 03:47 AM
Disco's Avatar
There's no need for the vtec function if your engines rpm's never drop below say 5k. So guys with big money and even bigger aspirations modify their heads to lessen the mass of all the moving parts.
Old 12-15-2012, 04:17 AM
Chugger's Avatar
My ferrea rocker arms utilizes a single lobe instead of twin lobes like web.
Old 12-15-2012, 06:59 AM
hondab18b67's Avatar
Do you have to run web's valve train or can you run any upgraded valve train with this set up
Old 12-15-2012, 08:22 AM
Sickteg24's Avatar
^^^ Chugger is big ballin! lol
Old 12-15-2012, 08:56 AM
SPOOLINmatt's Avatar
its the WEB Rocker arms that you need for their VtAk killer cams.
Old 12-15-2012, 09:02 AM
vtechjunkie's Avatar
Old 12-15-2012, 09:19 AM
Originally Posted by vtechjunkie
He is using vtec. He is utilizing a "cam trigger" kit to actuate it is all. If you look on the front(timing belt) side of the motor, you will see there is a sensor, and wire connected to the bracket. That bolts to the head where the power steering used to. That senses a magnet in the cam gear, and tell the compute what the rpm is. Everything else can be take off of the other side of the motor now. And this kit is more accurate as well.
You're either joking or you need to STOP posting in HT technical forums.
Old 12-15-2012, 09:44 AM
jdm inc's Avatar
too much vtak!
Old 12-15-2012, 10:00 AM
dreadcivicturbo's Avatar
Blink
Old 12-15-2012, 10:41 AM
PhilStubbs's Avatar
Lol, how would the rocker arms lock together without oil pressure from the solenoid? 3k posts, its time to start reading and stop posting.
Old 12-15-2012, 11:18 AM
Got traction's Avatar
hahaha
Old 12-15-2012, 12:14 PM
Sleeper.SEDAN's Avatar
Old 12-15-2012, 01:07 PM
ekcoupeh22's Avatar
Old 12-15-2012, 01:59 PM
zeekman's Avatar
looks like hes missing top tranny bolt
Old 12-15-2012, 02:14 PM
MoiMotorsports's Avatar
i have herd the best way to go is web cams ..with the pads some of the roller setups dont work out
Old 12-15-2012, 02:43 PM
a1320addict's Avatar
that's an interesting concept you have there.
Old 12-15-2012, 09:28 PM
DDTECH's Avatar
ugh.. two things
vtechjunkie needs to edit his post lol..
and moimotorsports needs a better header.
Old 12-15-2012, 09:49 PM
xohcef's Avatar
Originally Posted by ALL M0T0R
ugh.. two things
No1 totally agree
No2 couldnt agree more
Old 12-15-2012, 10:08 PM
That was an expensive xs power knock off manifold how are you a knock off of a knock off is that even legal lol
Old 12-16-2012, 01:26 AM
Originally Posted by xohcef
No1 totally agree
i hope my new setup is okay with u guys
Old 12-16-2012, 03:14 AM
PhilStubbs's Avatar
No1 totally agree
I'd also like to see him change his name so vtec was spelled properly, being the vtec expert he is.
In his mind copying a copy cancels everything out and it's an original idea again.
Quick Reply: Eliminating Vtec Solenoid?
