Difficulty nailing a good Et
Old Aug 30, 2005 | 08:26 AM
TypeRPaul's Avatar
Default Difficulty nailing a good Et
Could someone please give me some insight to what I might be doing wrong, I cant seem to nail a good ET at the track with my new setup. The setup is listed in my sig along with a link to my dyno. So far the best I can hit is in the 14.6, which is what i could hit with i/e. Granted my tires are nitto 455's and dont hook up that great, but I lower the psi to about 21psi and drop the clutch at about 5.3k and feather the gas. I hit hight 2.2 60 footers and my trap speed is around 97-98 at the end, what am i doing wrong? sorry if this is jumbled it was a long night and i cant see strait.
Old Aug 30, 2005 | 08:40 AM
nasteboyii's Avatar
Default Re: Difficulty nailing a good Et (TypeRPaul)
lower tire pressure to 15, u want to spin as little as possible but still spin enough not to bog, thats it
PRELOAD, by pullin up to light/line, pull up ebrake hold up, put in first slip clutch enough to trip lights, then hold clutch just before moving vehicle but enough that it shifts the car s weight alittle, then right before leavin, slip clutch still holding throttle and drop ebrake and floor it
its a practice game, but basicaaly u want car to slide out of box with out DUMPING clutch since that will cause tire spin
play with this alittle but its quick typing for me, so if u dont understand something holla back
later and good luck
dan
Old Aug 30, 2005 | 08:49 AM
TypeRPaul's Avatar
thanks for the info, i can drop it down to 15 psi wirthout spining my tire off my rim?
Old Aug 30, 2005 | 10:04 AM
nasteboyii's Avatar
Default Re: (TypeRPaul)
on a street tire i would not go lower then 15, drag radials ive been down to 9 fine, but again, more traction without bogging is what your ideal setup, if they bog on 15 raise it up alittle
d
Modified by nasteboyii at 1:51 AM 8/31/2005
Old Aug 30, 2005 | 10:30 AM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">Could someone please give me some insight to what I might be doing wrong, I cant seem to nail a good ET at the track with my new setup. The setup is listed in my sig along with a link to my dyno. So far the best I can hit is in the 14.6, which is what i could hit with i/e. Granted my tires are nitto 455's and dont hook up that great, but I lower the psi to about 21psi and drop the clutch at about 5.3k and feather the gas. I hit hight 2.2 60 footers and my trap speed is around 97-98 at the end, what am i doing wrong? sorry if this is jumbled it was a long night and i cant see strait. </TD></TR></TABLE>
How much does your car weigh? Are you considering using drag radials or slicks at the track?
Old Aug 30, 2005 | 11:54 AM
TypeRPaul's Avatar
its a full interior itr, yea im thinking about picking up two slips and some bfg's
Old Aug 30, 2005 | 12:27 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul &raquo;</TD></TR><TR><TD CLASS="quote">its a full interior itr, yea im thinking about picking up two slips and some bfg's</TD></TR></TABLE>
If you're not racing a street tire class and looking for the best E.T. possible I'd pick up a set of MT 22x8x15 slicks. They will cure ALL of your traction issues.
Phil
sporkcrx
Aug 20, 2004 06:01 AM
.M.
Mar 28, 2004 03:07 AM
MysticAzn03
Jan 23, 2003 09:40 AM
MyWhiteCivic
Jul 13, 2002 01:53 AM
sappsycho
Jun 12, 2002 06:28 AM
