Launching??
Old Jan 16, 2003 | 05:37 PM
MysticAzn03's Avatar
Default Launching??
What does everyone launch at on the track???
Any techniques????
Old Jan 16, 2003 | 06:33 PM
Integraholic's Avatar
Default Re: Launching?? (MysticAzn03)
Tire PSI - 20
RPM - 5100
Clutch - full dump
accelerator - feather to keep it off the rev limiter till you hook up
result - 2.2 60' times at least
I did it with just my intake and new tires. It seems to work with me.
Old Jan 16, 2003 | 06:46 PM
sic2kSi's Avatar
Default Re: Launching?? (Integraholic)
2K on street tires. Dumping the clutch.
Pretty well modded LS. Still gets some spin but not enough to change my ways.
Old Jan 16, 2003 | 08:48 PM
conesmasher's Avatar
I have heard that slipping the clutch does the best work of all. I work at a shop, so I have heard them all. One of my customers who drives a WRX and his wife drives a GSR says that, slipping the clutch gives the best 60 foot times. When he drove it he was pulling 2.0 60' times. It will alow you to get full traction while your clutch moderates the power.
Old Jan 16, 2003 | 09:03 PM
NX_LS's Avatar
I usually slip out the clutch from about 4.5k.
I also end up shifting into 2nd by the time I'm at the tree.............
Old Jan 16, 2003 | 11:13 PM
VtecB17A's Avatar
Default Re: Launching?? (NX_LS)
i hold it anywhere from 4000-4500 and baby out the clutch and dump it at the last second...gets a lil wheel spin on my azenis then its all good.
Old Jan 18, 2003 | 06:54 PM
wanna b R's Avatar
Default Re: Launching?? (VtecB17A)
3000rpm-4000rpm
Old Jan 18, 2003 | 06:57 PM
skunkintegra's Avatar
Default Re: Launching?? (wanna b R)
3000rpm-4000rpm
and no higher on my street tires....
Old Jan 19, 2003 | 12:02 PM
AWD: Jeff's Avatar
Default Re: Launching?? (skunkintegra)
i cant launch any higher than 1700 rpm. and i try to slip the clutch, it always gives me a nasty wheel hop. even a peel out through second gear. i guess its my suspension. im only running on skunk coilsover.
Old Jan 19, 2003 | 12:05 PM
Default Re: Launching?? (Dohc93hatch)
i think 1700 is too low...
all you will get is wheel hop and bog
[Modified by skunkintegra, 3:07 PM 1/19/2003]
Old Jan 19, 2003 | 12:09 PM
MrBite's Avatar
Old Jan 19, 2003 | 12:10 PM
rodimus's Avatar
what kind of tires do you have?
Old Jan 19, 2003 | 02:42 PM
10K2HVN's Avatar
Mmm...Lunch sounds good...at work with no break..i freaken starving!!
Old Jan 19, 2003 | 08:24 PM
AWD: Jeff's Avatar
i tried launching at 3000. all i got was to much wheel hop and n endless chirp in 1st gear and 2nd gear. 3rd gear was alright. n my car didnt bog out at all. i didnt get any wheel hop at 1700. i know it seems low, but i think i need a z10 radius bar, or adjustable shocks.
Old Jan 19, 2003 | 08:25 PM
AWD: Jeff's Avatar
Default Re: Launching?? (EVOL)
i hav falken zeix 502. there not the best. but it gets me places. i can spend them likk theres no tomorrow. maybe i just need bigger wheels. im running on 15 acura se.
Old Jan 19, 2003 | 11:03 PM
Sukebei Oni's Avatar
i usually just hold the gas pedal to the floor and let the engine bounce off the rev limiter and then drop the clutch and let the traction control handle traction. works best taking off in second gear like that.
Old Jan 20, 2003 | 04:58 PM
M-Type's Avatar
Default Re: Launching?? (Sukebei Oni)
the trick is to let off the cluch without gasing and right when the engine is about to choke you floor it and keep your foot there.
[Modified by M-Type, 1:59 AM 1/21/2003]
Old Jan 23, 2003 | 09:40 AM
All Motor EG's Avatar
Tire PSI - 20
RPM - 5100
Clutch - full dump
EXACTLY......seems he knows how to drive....same thing i do works the best....takes some practice though
sporkcrx
Aug 20, 2004 06:01 AM
CarbonfiberR
Aug 15, 2002 11:17 AM
sappsycho
Jun 12, 2002 06:28 AM
R-Rated
Dec 11, 2001 10:38 PM
