Deleting ignition switch and key and putting in toggle switches and push start
Old 07-10-2012, 06:49 PM
patroick67's Avatar
Default Deleting ignition switch and key and putting in toggle switches and push start
Well my ignition switch died in my 94 civic dx drag car and I priced one at my work and its 242 dollars before discount and its not something I can afford at the moment. I am trying to figure out is it possible to remove the ignition switch all together to where I can just use a push start for the car. I know this would make it very easy to steal the car but like I said this is my drag car and is under lock and key at all time. If someone could just point me in the right direction that would be great.
Old 07-10-2012, 07:28 PM
xenocron's Avatar
Default Re: Deleting ignition switch and key and putting in toggle switches and push start
Very easy to eliminate the key, just supply switched 12 volt to the fuse box like the key does, and hook up a momentary push button to send 12v to the starter motor
We make a nice panel that fits in your DIN slot (if no radio) but you can DIY for very cheap if you needed to
http://www.xenocron.com/racespec-swi...nel-p-730.html
Old 07-11-2012, 02:59 AM
patroick67's Avatar
Thank you for the help! Unfortunately that is where my gauges are installed or I'd probably go that route.
Old 07-11-2012, 03:01 AM
justnprsh07's Avatar
How about ppl that get ride of "all" the wiring and fuse boxes? Anyone have a wiring diagram??
Old 07-11-2012, 04:58 AM
hamma-head's Avatar
will this fit under the raido? where the try is? or do you have to remove the raido
Old 07-11-2012, 08:54 AM
B18c1turboedEK's Avatar
Use a obd2 harness and a arc 8000 and remove all the crap out of your car. Very easy to do.
Old 07-11-2012, 09:15 AM
KidFrost's Avatar
I had the exact same issue with my Drag Car.
Heres what I did.
http://s44.photobucket.com/albums/f4...162525edit.mp4
Remove key side of ignition, so you only have the plastic piece in the rear where the wires go in. Turn it to on and leave it. This can also be used as a theft deturent if u mount it under the dash and turn it to off when the car is not in use it will disable the whole ign.
Cut into the white power wire and install a toggle switch. This way the switch controls "Key On/ Key Off"
Then install an S2000 push button into your old keyhole. Its a perfect fit. Then wire it up with a simple 4 pin relay.
Like this.
This was the best and cleanest option for me, works great.. S2000 push button is like 40 bucks and the relay I stole from the relay box, for rear defrosters b.c. who needs them on a drag car, and some wire I did it for less than 50 bucks.
I mounted the toggle switch in to the dash where my raido used to be and took the time to solder all my connections then tidy up all my wires and works like OEM.
-KidFrost
Old 07-11-2012, 09:30 AM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Chris, I'll contact you.
Edit: thanks for the wiring diagram kid frost.
Old 07-11-2012, 11:23 AM
redboost10's Avatar
We got rid of both fuse boxes but still had all working lights and started with key and no toggle switches at all. It worked flawless and looked great
Old 07-11-2012, 02:58 PM
patroick67's Avatar
Thanks for the diagram pictures are always helpful when doing something like this. However I ended up using a universal ignition switch from my work to make things easier and hid it up under the dash.
Old 07-11-2012, 05:25 PM
xenocron's Avatar
If you have a Full Din Slot under your radio yes...most of those spaces under the radio in Hondas are a full DIN though I dont think.
Old 07-12-2012, 04:41 PM
hamma-head's Avatar
sweet man i will be ordering this soon.. i looked at yalls web site and seen the one with the red switch thats the one i want
Old 07-12-2012, 04:56 PM
.adam.'s Avatar
arc panels are the **** and convenient
Old 07-12-2012, 06:36 PM
tepid1's Avatar
Yes, but big and bulky, plus the relay panel takes up space.
Best bang for the buck is the Xenocron setup.
Old 07-12-2012, 08:00 PM
1FASTHF's Avatar
I'm sure the relays you use with this switch panel also take up space..
Old 07-12-2012, 08:39 PM
a1320addict's Avatar
I mean, I'd rather have a fully sealed set of relays than a bare circuit board with plastic 'isolators'.
Old 07-13-2012, 02:59 AM
Pics? And how did u setup constant and switched powers to the ecu
How did u do it?
Old 07-13-2012, 05:57 PM
1FASTHF's Avatar
http://strd-online-2.myshopify.com/p...used-relay-box
Does it require space for installation?? Lol Sup Joel! I need to call you to get the rest of the stuff I need for my car.
Old 07-14-2012, 04:07 AM
ScorpioMk's Avatar
I have an arc panel/relay board, got rid of all the wiring except I reused the section of wire that goes to the back of the car for the tails.
solenoid under the dash for the kill switch, this kills the power to the engine as well as the switch panel.
and entire under dash and headlight harness.
Old 07-14-2012, 12:15 PM
were did you get all that from and around how much is it?
Old 07-14-2012, 01:20 PM
ScorpioMk's Avatar
jegs, 8 switch arc panel is 260. Solenoid is 114 and bought a few 50ft things of painless wire. All the connectors are the deutsch style kind from jegs or summit.
Old 03-01-2015, 08:49 AM
Daonlyone74's Avatar
Do you have a diagram or a diy how you did it?
Old 03-01-2015, 10:46 AM
xci_ed6's Avatar
On my '75 Honda it's basically a street legal race machine. I don't even have a a starter, you just have to kick it over (kick start). You just need to flip a switch to go, no keys. For security I'm going to hack a wireless switch to control run, so people can't mess with it. Well, they can mess with it all they want, but not go anywhere.
Oh, I did rewire it, completely.
rumham
02-21-2023 10:14 AM
h2oiamwater
11-26-2016 12:48 AM
azspd02
05-27-2012 06:37 PM
EnviedByMany
12-16-2010 05:34 AM
Un0Turb0-WP
10-19-2004 11:45 AM
Quick Reply: Deleting ignition switch and key and putting in toggle switches and push start
