Dec FS Thread
Five o motorsports denso 2000cc e85 injectors. Came off 88 rx7 looked it up they fit b, d & h hondas. High impendence with pigtails only have 1100 miles on them. 425 shipped
Have reciept of how much I paid and paperwork for flowrates & deadtimes
Call or text 208-899-seven six three eight
1988 Honda CRX drag car part out.
Crx drag shell includes fiberglass one piece front end, lexan windows, wheelie bars , roll cage , front traction bar setup , neusped drag coil springs, racing seat w/ harness , dash with tachometer and water temp gauge , parachute mount,handle and cable , and rolling chasis. $1600
Bosch 044 fuel pump with fittings
Victor X intake manifold for b16 / type r $175
HKS super sequential blow off valve $150
turbo xs RFL blow off valve $150
GM 3 bar map sensor new $50
GM turbo solenoid for boost control
gt3076 turbo has damage to turbine wheel from engine failure 700177-5011 chra part number Best offer
Hasport B series hydro engine mounts for 88-91 civic crx includes timing belt bracket $200
Aeromotive fuel pressure regulator for boost $100
4403 autometer boost gauge $40
3301 autometer boost gauge $40
Any questions text or call 530-515-9268
Last edited by aj99si; Dec 17, 2013 at 03:01 PM. Reason: added part / corrected part number
Posting for a friend on here, his screen name is scoop.
Brand new t1 Bseries coil cover 110.00
Brand New Garrett Blanked Cast End Tank For intercooler Welded Application 12" x 4.5" . one pair (2) end tanks. 110.00
I have a built gsr head not sure the year this was a back up head but I nolonger need it head has super tech everything head work was done by td autowerks head shop no td head has zero miles comes with what you see in the pics and gsr cams no cam gears vtec selinod included only flaw while taking the pics I turned the head and put 2 small scratches as seen in the pics I don't think its bad just wanted to mention everything price 850 shipped and paypal'd.
skinnies sold to eksleeper97
Email -- James@IPGParts.com
Phone -- 407-324-4684
sold sold sold sold
Selling my personal set of BBS Drag Wheels. I have owned these for 2-3 years now. I knew how rare they were before we got the Barn Find batch of BBS Drag Wheels so I hunted these down and after 6 months of trying the previous owner decided to sell them to me. Once I got them we completely tore them down, had CCW fully polish them and the fronts were re-assembled with ARP Hardware.
There isn't another set of Polished BBS Drag Wheels currently out there. These have not had tires even mounted on them since being reconditioned.
2x Front - 13x8, 4x100
2x Rear - 15x3.5, 4x100 - Extremely Light
With all of our test fitting we have only been able to verify that these will fit a Civic Spindle setup (small brake setup) with the use of a 10mm spacer for caliper clearance. We have been unable to fit them on an Integra Spindle car (but if you want to try and your own feel free). The issue isn’t the backspacing it is the way the back of the face of the 4×100 center is designed, it is very flat and it needs to be pushed off the caliper (with the use of a spacer) to get the caliper clearance required to work. You may be able to use them on an Integra Spindle with enough spacer size used but we have tested up to a 15mm size and have not successfully fitted them. Also will require the use of extended wheel studs.
We have been running a similar setup on Tom's K20 CRX at the Drag Strip and they are a conversation starter wherever they go.
sold sold sold sold
B18A1 Golden Eagle Sleeved Block. Currently at 84mm, needs to be bored to 84.5mm. Great shape, just had as a back up. $1000 OBO plus shipping and paypal fees.
GSR Trans with Mfactory lsd. Shifts perfect. $1000 OBO plus shipping and paypal fees.
Blueridge 44mm Dumptube. $40
Autopower adjustable seat brace for 1 3/4" bar. $100
Innovative Mounts for Ek 62A Rubber. $200
GSR Cams. $50
GSR Cams. $50
I have the following parts for sale. They are with me in Nor Cal and can be shipped to the lower 48 via USPS or Fed Ex Ground.
OBD2 P72 virgin ECU
$150
OBD1 P28 chipped ECU (chipped for S200 style by HONDATA)
$125
Moates Burn 1 chip burner
$75
Moates Ostrich tuner
$100
Brand new AEM B series black cam gears
$125 for the pair
Brand new AEM B series silver fuel rail
$75
Brand new Full-Race vacuum manifold
$25
Used Golden Eagle vacuum manifold (comes with some fittings)
$25
Brand new VMS purple rear tow hook
$50
Any questions let me know.
Jason
510-459-7229
OBD2 P72 virgin ECU
$150
$125
$75
$100
$125 for the pair
$75
$25
$25
$50
Jason
510-459-7229
OK everyone thinking about selling the car so throwing this up see if i get interest. its a 1999 Acura Integra GSR with 117k miles on the body. 3k on the drivetrain and 1k on the suspension. Also comes with a 1993 Honda Civic DX hatchback that is gutted and all sound deadening removed, everything behind dash removed, and ready for a cage. just a roller with a dash and steering wheel and column with panels and carpet. BOTH HAVE CLEAN TITLE.
it has full built laskey race engine with a GSR tranny that has mfactory 4.05 final drive, mfactory carbon lined syncros, and mfactory helical LSD. engine was sleeved by bensen and everything else done by laskey racing in cali. The head has a stage 3 port and polish from port flow as well. have all paperwork from laskey when he did all the work.
Laskey Racing short block
- Benson sleeved block
- Benson balanced and micropolished crank
- CP pistons and rings
- Pauter rods
- ACL Bearings
- OEM (TypeR) oil pump
- Lower gasket set
- Blueprint and assembly
also OEM timing belt, tensioner, and water pump.
moroso steel oil pan.
Laskey Racing stage 3 head
- PortFlow port & polish, SuperTech Stainless Steel nitride coated intake valves, Incanal(sp.) exhaust valves dual valve springs, titanium retainers, competition 3 angle valve job, surfaced to a mirror like finish and assembly
Has Hondata coil on plug that made a HUGE difference and one of the best things i have done to the car.
Full Race ProAm traction bar
T1 Race development catch can
AEM fuel rail
hasport motor mounts
moroso oil pan
carbon lined 1-5 synchro kit from mfactory
4.05 final drive from mfactory
helical LSD from mfactory
Skunk2 tuner 1 cams
ACT 12.5lb flywheel
ARP head studs
ATI super dampner
competition Stage 5 clutch with upgraded pressure plate
aeromotive 340 stealth fuel pump
aeromotive fuel pressure regulator
Precision 1000cc injectors with clips
BDL cam gears
BDL 70mm throttle body
Edelbrock vickerx intake manifold
BDL cam seal
Greddy Full auto turbo timer
PWR half size radiator
3" thermal turbo exhaust
Drive shaft shop 5.9 axles, hubs and extended wheel studs
Omni 4 bar map sensor
new TPS
powder coated valve cover with -10an bungs for catch can lines
AEM boost controller with low boost set at 9 psi (384 hp) and high boost set at 22 psi (456 hp)
car is tuned on hondata s300 on e85
AFI Street turbo kit
-AFI Tubular 304 ss Ramhorn manifold
- AFI 3" 304 ss down pipe with stainless braided flex and O2 bung
- AFI DIY dump tube kit
- AFI/Garrett 26X6.5X3.5 Back door intercooler
- AFI 2.5" mandrel bent and bead rolled black texture powder coated charge piping
- Garrett T3/TO4E Turbocharger- .57 trim
- Tial 38mm Waste gate
- Tial 50mm Blow Off Valve
- PWR 4 ply silicone couplers
- AFI Braided Stainless Teflon oil line kit
- T-Bolt clamps
- Billet fittings and turbo oil drain kit
- All Misc. Hardware and Gaskets
SUSPENSION:
- ground control coilovers with koni yellow shocks
- front springs are 8.6k and rear springs are 10.4k
- ASR rear subframe brace with type R rear sway bar
EXTRAS:
- 6765 ball bearing billet turbo t3 with .82 rear housing
- -8 feed -6 return steel braided fuel line
- Inline fuel filter
- dual pump hanger with -8 and -6 bungs in the hat
- brand new 340 pump
- fuel injector clinic 2000cc injectors
- Golden eagle fuel rail
i think there are a few missing things missing and i will add as i remember them.
if you have any questions just message me on here or text me would be the best way to reach me.
the car did 491 whp and 408 ft lbs of tq on 27 psi. and on 22 psi that is high boost right now is 456 hp and 380 tq. and did 384 hp at the wheels on 9 psi.
the whole driveline has 3k miles on it and gets driven around once every 2 to 3 weeks. car runs amazing and like a rocket ship.
asking price of $18,000 OBO
if you have any questions best way to get ahold of me is texting me at 505 8one4 4five74
Only reason i am selling is i dont drive the car anymore and just sits in the garage and either going to be building a shop in my back yard or putting the money into the house
and here are some pics. i can take pics of anything you want just let me know what you want to see.
Also the car has been to the track 2 times and has been down the track 7 times and ran awesome.
car did 11.750 at 120 mph and the run right after did 11.80 at 118 mph. this is also at 5500 ft elevation with a DA of 7,000 ft
- Pauter rods
- ACL Bearings
- Lower gasket set
AEM fuel rail
moroso oil pan
Skunk2 tuner 1 cams
ACT 12.5lb flywheel
ARP head studs
ATI super dampner
BDL cam gears
BDL cam seal
new TPS
- T-Bolt clamps
SUSPENSION:
EXTRAS:
Email/Paypal: Daryl700hp@yahoo.com
State: KY
Phone: 502-492-363four
I have decided to upgrade everything of the winter, everything works great and came off while the car was running.
Buyer must cover paypal and shipping fees.
I made 540whp on this setup and never had a issue with anything here.
Turbo: GT35R Ball Bearing , .63/70 T3 housing with 4 bolt exhaust. $500
Cam: GSR, Unknown miles but in great shape. $80
Mani: Spooling performance, T3 but also drilled for t4. Fits a 46mm PTE wastegate, Also 44mm I believe. Comes with dump tube. $400
Intercooler: Emusa, Got beat up some in a storm but works fine, Also a burn mark for the dump.
$50
Downpipe: It is a side exit 3in out the bumper for my eg, also a 4 bolt. $100
IC Piping: Unknown brand, Fit my eg fine. Works fine with no holes, Comes with couplers and clamps. $100
BOV: Blitz 2 bolt, Works fine. $100
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
State: KY
$50Downpipe: It is a side exit 3in out the bumper for my eg, also a 4 bolt. $100
[IMG]
[/IMG] [IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[IMG]
[/IMG]
new M&W pro14 cdi box. purchased a few months ago, wired in and never ran the car. ended up changing to smart coils...
selling as a bulk package, and will include:
M&W pro14 box
complete harness
new in package harness plug w/pins and rubber grommets
8 coils-4cbr and 4gsxr
asking $800 OBRO
please text me as i am not on here often...thx 774-319-9072 justin
M&W pro14 box
complete harness
asking $800 OBRO
All prices are + shipping and paypal fees.
Used Golden eagle B series head studs-$90
Used oversized flat bottom valves. I think they are +1mm. $100
UPR billet intercooler water tank lid-SOLD
New Honda engine bearings-$125
There are 26 bearings in there. Probably $250 worth.
15 used Supertech valve spring retainers. 1 missing for some reason.-$75
New MSD distributor cap for b series-$35
MSD HVC 2 coils. 3 to choose from-$100 each
AEM fuel rail for b series with sample valve and SX regulator-$150
PWR radiator w/Spal fan for 92-95 civic-$150
Turbo smart 40mm wastegate-$200
Hks bov-$50
Unknown intercooler-$50
OG B series Spec twin disc clutch-SOLD
Intercooler water tank-$50
F22 drag turbo manifold-$50
B18C1 CNC race head for sale. This head was used in the BRE Hot Rod car, but has been reworked with a new valve job from CNC. It's all done, just needs to be professionally assembled. I know I would prefer it this way so everything can be confirmed to be correct during assembly. Valves, springs, and retainers are Ferrea. Comes with keepers, shims, and seal. All cam caps and oil rails included too. $1250
Xenocron b series cam degree kit. SOLD
JG Edelbrock intake for B18c1 $225
BDL 70mm throttle body-$200
Weldon 2025 fuel pump with fresh rebuild from Weldon. Filters included-$500
MSD 75314 4cyl ignition box w traction control-$500. This is a $1000 box FYI!
Stock B18C1 longblock, new cam seals, rear main seal, oil pan gasket, valve cover gasket, oil pump, water pump, tensioner, and timing belt. Was gonna be my beater engine, do it's got everything you need new to mske it run for a long time. $1250 timing belt and cover not in pic. also, will have stock oil pan and pickup installed.
Hks bov-$50
I has a b18 short block sold car no longer need. 81.25bore je pistons, eagle rods, endyne girdle,arp everything, comp was mid 8s have to find piston card.
$1000 pick up, will drive short distance for few dollars in fuel.
precision 46mm new all springs $250 shipped
Omni billet rear control arms$150 shipped
ingals upper control arms $60 shipped.
in markelville Indiana. kinda hard get online txt fastest way to reach me.765 748 0070
T1 fan shroud and spal fan
heres there link brand new
http://www.t1racedevelopment.com/ind...oud-combo.html
300 shipped I payed almost 400 never used!!!
Got a few parts for sale everything is in Good shape any questions pm or text me 240 216 1030 i take paypal and i can ship for extra thanks
T4 6266 82 ar vband exhaust housing 20 miles on it 800 obo
Hondata p28 ecu with boost control and s300 500 obo
Tial 50mm bov polished 180 obo
Inline pro b series stainless t3/t4 manifold 250 obo
Turbosmart 38mm wastegate and dumptube 175 obo
Ek intercooler piping with bov 180 obo
3" downpipe for the inline manifold has vband for the turbo side 130 obo
Brand new b series Clutch master stage 4 clutch kit 350
Brand new act b series flywheel 125
B series vtec valve cover Powder coated wrinkle black 100
Brand new Single cam tempest racing ramhorn turbo manifold t3/44mm 450
