control arm hitting on crx
Old Feb 8, 2012 | 05:46 PM
2.6lrex's Avatar
Default control arm hitting on crx
Noticed this tonight as i was working on my pile of junk.
Has anyone else ran into this issue, i would like lower the car more but untill i figure out a fix it wont happen
using strange front struts and stock upper control arms with camber hits.
thanks for the help in advance
Old Feb 8, 2012 | 06:34 PM
sohcd16's Avatar
Default Re: control arm hitting on crx
Ithink it is fairly common on crx's. Mine was like that with my camber kit so I just hammered that lip out and it never hit again.
Old Feb 8, 2012 | 06:52 PM
slowboy90's Avatar
what strange setup are you running i have a DA wanting to know
Old Feb 8, 2012 | 07:10 PM
sanman000719's Avatar
stock control arm????
i have a crx as well and never ran into this issue
Old Feb 8, 2012 | 07:12 PM
that upper balljoint looks funky to me as well
Old Feb 8, 2012 | 08:50 PM
Swipe'd's Avatar
the junk2 upper control arms supposedly doesn't hit.. i haven't had the chance to use it yet.
honestly, i bought the Rhino upper control arms on my old street car. no issues with hitting or clearance. however the ball joint boots did tear with little miles on em.
good luck and let us know how it goes..
running same front struts. i wont be using those camber kits. they are VERY poorly made and ive seen them fail too many times to put on my race car.
~cheers
Old Feb 8, 2012 | 08:59 PM
1FASTHF's Avatar
As stated before... just "clearance" the contact point and you should be good. I had to do that to my CRX as the that type of camber kit moves the control arm outward.
Old Feb 9, 2012 | 07:27 AM
90b16dx's Avatar
U have the ingalls style camber kit and they push the contol arm out too much... Either notch the pinch weld or put skunk 2 control arms on it
Old Feb 9, 2012 | 08:40 AM
ESP.net's Avatar
My cheap but trusty rhino adjustable uca's required notching that part not a big deal, get a die grinder and make some clearance
or
SKUNK2
Old Feb 9, 2012 | 09:28 AM
2.6lrex's Avatar
hanks for the input, i was thinking of cutting the lip or going with the skunk 2 stuff
Old Feb 9, 2012 | 09:42 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
I wouldn't cut that out.. just bend that lip over with a clearance tool..aka hammer..lol. I don't like to cut metal away from places like that..
Old Feb 10, 2012 | 02:10 AM
93supercoupe's Avatar
i ran into this issue when i put DA control arms on my rex
Old Feb 10, 2012 | 04:41 AM
Kevin's Avatar
I've just hammered it flat in all of my cars using a small sledge. The control arm doesn't hit on my DA but the tires do and it leaves a nasty gouge in the top of the slick if you don't hammer it flat.
Old Feb 10, 2012 | 10:59 AM
raene's Avatar
I ground away the lip on the UCA on mine. Did it ages ago, zero problems.
Old Feb 10, 2012 | 06:20 PM
2.6lrex's Avatar
ordered shunk 2 control arms today plus im going to cut the lip and weld it back up
Old Feb 11, 2012 | 04:55 AM
xenocron's Avatar
Yeah I did both on mine as well
97elitehonda
Suspension & Brakes
May 7, 2007 10:06 AM
quick_ls
May 26, 2005 01:40 PM
CD7power
Jan 14, 2005 02:34 PM
Groove_D
Apr 9, 2004 11:21 PM
TurboFryBox
Apr 23, 2003 10:51 AM
