CNCWerx CSS Block Cut In Half!!!!
Old May 4, 2016 | 03:52 PM
  #151
trickeng's Avatar
Default Re: CNCWerx CSS Block Cut In Half!!!!
Originally Posted by Malone03
Any B20B Dyno numbers out there yet? trying to decide on sending the B20 or just getting a B18 short block to tear down and send.
B20's are very weak compared to a B18 and not recommended over 400hp. Even it your buddies friend ran 900 for 3years and he loves B20's. Weak Weak Cylinder Design and not recommended for boosted applications over 400hp.
Old May 4, 2016 | 03:57 PM
  #152
Malone03's Avatar
Thanks I will start to shop around for a b18 block,
Old May 16, 2016 | 09:34 AM
  #153
KarlSeries's Avatar
In this case for less than 400hp B20's still recommended??? as previously stated you work on the standard sleeve I'll assume you cannot go bigger than 85mm. Am I correct!?
Thanks.
Old May 16, 2016 | 01:04 PM
  #154
kingofbattle909's Avatar
Old Mar 29, 2017 | 07:09 AM
  #155
johnie1199's Avatar
10 Year Member
I finally cracked mine at 780whp on first qualifying run at tx2k we were going to turn it up oh well
Old Mar 29, 2017 | 07:14 AM
  #156
AZ_CIVIC's Avatar
That sucks!! You planning on running a sleeved block this time or another CSS?
Doesn't CSS say they warranty their stuff?
Old Mar 29, 2017 | 01:03 PM
  #157
1HGEJ2's Avatar
780whp is really good
Old Mar 29, 2017 | 01:45 PM
  #158
drmix's Avatar
Their warranty is for a year and under 500whp
Old Mar 29, 2017 | 01:55 PM
  #159
AZ_CIVIC's Avatar
I guess a sleeved block it is.
Old Mar 29, 2017 | 03:12 PM
  #160
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
The guy that owns CSS leaves a worse impression than Dave Hsu.
I've literally never seen a more immature business owner. I wouldn't touch a CSS block with a 10 foot pole.
Old Mar 29, 2017 | 03:34 PM
  #161
pogeeboy27's Avatar
Waiting on response from OP.
Old Mar 29, 2017 | 04:48 PM
  #162
2LEM1's Avatar
I like to party
Community Builder
Jeesh, I'm grumpy today.
I think I'm channeling Grumpymarc through my posts today, I've really been on one.
Old Mar 29, 2017 | 05:01 PM
  #163
pogeeboy27's Avatar
No joke. You went off in that Trump thread.
Old Mar 30, 2017 | 12:05 PM
  #164
JDMarv's Avatar
its only a 500whp guarantee lol - opps didnt see above comments lol. sorry to hear about the block! hopefully youre back out again soon!
Old Mar 30, 2017 | 04:14 PM
  #165
ShinsenTuner's Avatar
No Jodas
What happened?
Jeff has always been a very helpful and knowledgable person. I've worked with him personally and have nothing but good things to say about CSS and him as a person. So I'm curious where your angle is from.
Old Mar 30, 2017 | 04:16 PM
  #166
SwappedTURBOegg's Avatar
i wonder if oring the block made it weaker
Old Mar 30, 2017 | 04:59 PM
  #167
pogeeboy27's Avatar
Right, but that's not the point.
Post #10
Yosolo has tuned two cars from R&R/Eggy racing NJ. One has been running for over two years (first year at mid 500's low 10's, second year + at mid 600's and high 9's). This motor is now going into a RWD Datsun. Second motor ran all last year in the mid 600's high 9's and just got retuned to 734whp.
GoAutoworks has a 500+hp D16 streetcar which has been running for at least 6month.
And most impressive is the fact that there has been ZERO customer failure to date.
Post #112
Yes and ZERO customer cracked blocks to date.
Post #122
4years, over 100 motors done and ZERO customer failures to date including all series blocks and the car making between 650-800hp.
I know TDC Performance has a Dseries customer running over 500 and it been almost a year now. Other than that no real info to report on max numbers.
Looks like the limit for CSS has been found. Not dissing on this product at all but I feel it does have its place.
Old Apr 1, 2017 | 08:15 PM
  #168
2LEM1's Avatar
I like to party
Community Builder
Originally Posted by ShinsenTuner
What happened?
I'll PM you.
Old Apr 3, 2017 | 05:24 AM
  #169
johnie1199's Avatar
10 Year Member
I already bought a sleeved motor know css works but remember it's 500hp warranty I was over that it work but if you are pushing it it's best to have a sleeved motor that's all there's no angle I was just updating and yes I be out in about a month sucks because I know that car was moving at tx2k but oh well next time
Old Apr 3, 2017 | 05:41 AM
  #170
johnie1199's Avatar
10 Year Member
I believe only if your under 500hp it's understandable and the o-ring was ok when torqued when it cracked it pushed the oring up very curious how that happened but like I said this thing was moving for sure
Old Apr 3, 2017 | 06:45 AM
  #171
AZ_CIVIC's Avatar
I've said it before CSS has a place for guys who don't want to spend a bit more money and limit their power to that 500whp range. Most people who get to those types of power levels however always end up wanting to push more and of course you end up with a cracked sleeve.
The thing I never liked about the guy/owner or whoever was the fact that they make it seem like if you send your block in the entire process is $300 bucks and you're ready to go. If you look at their website to get the block done and I mean done in the sense that they have done their process, decked, bored, hone and even o'ring that it is more along the lines of $700 plus.
They also always mention that sleeving a block costs like 2k plus which again is also false, a sleeved MID Darton block is around $1400 done and ready to go, I paid $1250 for my Golden Eagle sleeved and O'ringed block.
So again the CSS process has a place but don't go around saying the CSS process is 10 times cheaper, when in fact it is tops half the price. Also getting a sleeved block for double the price is justified in the sense that it is sleeved, you have more room to up your bore, if you damage a Darton sleeve you can replace which ever sleeve is damaged. Not to mention you can run 1000whp and not wonder if the stock sleeve will last.
Just my 2 pennies.
Old May 22, 2017 | 04:52 PM
  #172
trickeng's Avatar
Out of over 3000 Blocks done world wide. johnie1199 was one of 8 people to "EVER" crack a cylinder without it being catastrophic failure. No sleeving company on earth can say out of 3000 blocks less than 8 sank a sleeve which is comparable since you have to tear down your entire drivetrain and engine to send back the bare block to be warrantied IF you are within there warranty guidelines.
CSS still relies on the factory casting which are far more reliable than some machinist pumping out sleeve jobs.
So 8 out of over 3000!!! I'm good with those numbers. Specially when I continue to post up 800-900-1000HP success stories. Hundreds of them.
blackeg
Jan 14, 2012 04:41 PM
boostjunkieee
Mar 5, 2007 12:39 AM
Captian_Honda
Mar 21, 2005 02:12 PM
kabaroo
Oct 11, 2004 12:43 PM
madman604
May 23, 2003 04:19 PM
