CNCWerx CSS Block Cut In Half!!!!
Old Jan 9, 2013 | 10:30 PM
  #101
Spawne32's Avatar
Default Re: CNCWerx CSS Block Cut In Half!!!!
do you have any pictures of this on a B20 block?
Old Jan 9, 2013 | 11:34 PM
  #102
dcmatt's Avatar
Your best bet is to email him. The address is on his website.
Old Jan 10, 2013 | 05:02 AM
  #103
trickeng's Avatar
Originally Posted by Pendmn
Mikey from Profunction recommended me to do business with you jeff. i had texted you but im guessing your phone doesnt accept text messages. can you PM me how much would it cost to do a Cylinder Support System to my d16 block. its actually a ZC but its the same as a d16y7 and another question is ive never sent out a block out before so how does shipping go for and who do i work with to get my block sent out to you. i hope to hear from you soon jeff. thank you.
Oh I accept text. 24/7!!! My cell is (978)337-3234.
Old Jan 10, 2013 | 10:36 AM
  #104
trickeng's Avatar
Here is one we just took off the machine.
Old Jan 10, 2013 | 12:14 PM
  #105
01DC4's Avatar
Do these blocks need decked after this or do you deck them?
Old Jan 10, 2013 | 12:24 PM
  #106
trickeng's Avatar
The CSS process does not include finish machine work. So yes, it would have to be decked.
Old Jan 10, 2013 | 12:37 PM
  #107
poorboy44's Avatar
anyone used this for bigger bore all motor/nitrous setups?
Old Jan 10, 2013 | 12:41 PM
  #108
trickeng's Avatar
The CSS does not replace the sleeves so you can only go to the maximum bore of stock sleeves.
There are a couple 9sec 82mm B18's out there with the CSS.
Old Jan 10, 2013 | 02:04 PM
  #109
93supercoupe's Avatar
is it just the top portion of the sleeve thats supported? or is it an insert that goes the whole length of the sleeve?
Can you take your first pic and point out whats stock and whats not?
Old Jan 10, 2013 | 02:12 PM
  #110
trickeng's Avatar
??? The support ring is only at the top and the ring is the defined square piece at the top of the water passage.
Old Jan 10, 2013 | 11:27 PM
  #111
SoHc94's Avatar
is this available for the b20? and how are they doing with the b20 famous cracking? any help at all?
Old Jan 12, 2013 | 05:43 AM
  #112
trickeng's Avatar
Yes and ZERO customer cracked blocks to date.
Old Jan 13, 2013 | 06:31 PM
  #113
92egdxhatch's Avatar
For additional $ do you offer final bore/hone/decking?
Old Jan 13, 2013 | 06:43 PM
  #114
trickeng's Avatar
Of course!!!
Old Jan 13, 2013 | 07:52 PM
  #115
93ls10.0's Avatar
F22 available?
Old Jan 14, 2013 | 03:00 AM
  #116
trickeng's Avatar
Originally Posted by 93ls10.0
F22 available?
Yes
Old Jan 15, 2013 | 04:39 AM
  #117
1320em1's Avatar
hear some picks of my friends coupe b-seriesdelslo with the cncwerx css. it made 600 on a mustang dyno 28psi on a precision 67mm cast wheel running out of pump on e85 .tuned by chad from noribilt , track times coming soon...
Old Jan 15, 2013 | 08:56 AM
  #118
B-Seriesdelslo's Avatar
^ thanks for posting the pics up for me brotha
Old Jan 16, 2013 | 02:45 PM
  #119
theidealone's Avatar
Any D16 failures? What's the most power you've seen consistently applied to a CSS D16 block?
Old Jan 16, 2013 | 04:10 PM
  #120
mad_affliated's Avatar
Keep it up that's beast
Old Jan 16, 2013 | 04:41 PM
  #121
That's clean!
Old Jan 16, 2013 | 05:31 PM
  #122
trickeng's Avatar
4years, over 100 motors done and ZERO customer failures to date including all series blocks and the car making between 650-800hp.
I know TDC Performance has a Dseries customer running over 500 and it been almost a year now. Other than that no real info to report on max numbers.
Old Jan 16, 2013 | 08:22 PM
  #123
OBRJosh's Avatar
Originally Posted by 1320em1
hear some picks of my friends coupe b-seriesdelslo with the cncwerx css. it made 600 on a mustang dyno 28psi on a precision 67mm cast wheel running out of pump on e85 .tuned by chad from noribilt , TRACK TIMES COMING SOON FRIDAY NIGHT AT IMPORT NIGHT?
Attachment 305624
Attachment 305625
Old Jan 17, 2013 | 09:18 AM
  #124
^ yes sir we'll be at import night lol
And thanks for the compliments!
Old Jun 20, 2013 | 09:48 AM
  #125
Langford360's Avatar
Have the CSS on a new sc set up we are working on and it's handling right about 300 foot pounds of trq at 3500 rpm all day! This is on a dd with no heat issues what so ever.
