broken axle lsd
Old May 25, 2008 | 02:00 PM
topp_dawg_g's Avatar
From: springdale, arkansas, United States of America
Default broken axle lsd
went to the drag and bust my axle. the driver side axle is broken by the hub. its spinning both in gear or out but what i don't understand is that even in gear my right axle is not sprinning. could it be a tranny problem.
Old May 25, 2008 | 02:24 PM
1992Si's Avatar
When these cars break an axle the car will not move on it's own.
Replace the axle and let us know if the problem goes away.
Even with a Quaife when the right axle popped out the car would not move.
Put a good axle in the drivers side.
Old May 25, 2008 | 10:00 PM
civickiller's Avatar
Default Re: (1992Si)
on gear type lsd, you need some resistance on both of the axles for the lsd to work, ie if you break an axles, that side no longer has any resistance for it to work.
only on clutch type lsd's will it still work if you break one side so you can drive
Old May 27, 2008 | 04:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (civickiller)
but even still that depends on how tight the clutches are.
a true spool is the only way a car will definately move if an axle is broken, unless the diff is welded, catastrophic failure yadda yadda.
topp_dawg_g
May 25, 2008 06:17 PM
racin_jayson
Feb 6, 2008 03:10 PM
Maxime
Sep 1, 2006 07:40 AM
XX Boosted Si XX
Jun 27, 2006 04:48 AM
longuyen88
Jun 16, 2006 09:41 PM
