For Boost Dome Or Flat Top
Old Mar 16, 2010 | 05:39 PM
nitrotiger's Avatar
Default For Boost Dome Or Flat Top
Ok i been searching and still cant find all the info i need. It seems more people favor flat top pistons over dome? can anyone give me there honest opinion. Was planning to run at least 10:1 i believe that seems to be the max on that piston. But correct me if i am wrong.
Old Mar 16, 2010 | 08:08 PM
nitrotiger's Avatar
Default Re: For Boost Dome Or Flat Top
anyone ?
Old Mar 16, 2010 | 08:11 PM
lsvtechatch92's Avatar
some people run domed pistons on boost.... the reason a bunch of people dont do it is b/c its super high compression with boost and its hard to make good power on pump gas without detonating ..... with race gas it shouldnt be a problem... but 10:1 is a perfectly fine compression for boost... my new setup is 10:6:1 and will be on pump and race gas
Old Mar 16, 2010 | 08:17 PM
nitrotiger's Avatar
thanks sounds good. Some flat top is safer is what your saying?
Old Mar 16, 2010 | 08:42 PM
cibao2ner's Avatar
flat top piston create a more efficient combustion..so yea they are safer and anything dome will have a higher compression..depends what your set ups is..but for boost dish or flat is better
Old Mar 17, 2010 | 06:18 AM
1.5Slowmatic's Avatar
how do flat tops create more efficient combustion than a piston with a small dome on it?
Old Mar 17, 2010 | 08:11 AM
raene's Avatar
Think how the combustion pushes against the surface of the piston and it should be clear.
GSR_hatch936
Feb 12, 2010 09:24 AM
stefz
Jan 29, 2009 08:22 AM
ivebenjamin
Feb 2, 2006 11:34 PM
Spooled1.6L
Feb 4, 2004 05:40 AM
D-SPEED
Jul 25, 2001 07:56 PM
