b-20
Old May 11, 2004 | 05:05 PM
ronnieb's Avatar
Default b-20
will a us b-20b4 pass smog in a 98 civic ex
Old May 11, 2004 | 08:00 PM
94gsr4dr's Avatar
Default Re: b-20 (calicivicsi)
what other mods to the car?
Old May 11, 2004 | 10:43 PM
Reason's Avatar
Not out here in california...... because its a motor for a truck.
Old May 12, 2004 | 04:20 AM
killer hatch's Avatar
a helpful tip. if you dont want topay an arm and a leg. put everything back to stock. all the vac lines intake exaust everything. take the carto a smog ref register the motor and it will. just make sure that every time you go to smog the car that you put it back to stock. if you can get the smog ref to certify your motor then they have to do the smog test for your motor not your car. i have to the same thing to my h22 eg. good luck.
Old May 12, 2004 | 12:34 PM
michael O's Avatar
Default Re: b-20 (killer hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killer hatch &raquo;</TD></TR><TR><TD CLASS="quote"> a helpful tip. if you dont want topay an arm and a leg. put everything back to stock. all the vac lines intake exaust everything. take the carto a smog ref register the motor and it will. just make sure that every time you go to smog the car that you put it back to stock. if you can get the smog ref to certify your motor then they have to do the smog test for your motor not your car. i have to the same thing to my h22 eg. good luck.</TD></TR></TABLE>
that would work if it was a car engine but it's not it's from a truck and will not pass at a smog ref or an honest smog shop.
mike03,95civic
Aug 17, 2007 05:38 PM
asocallocal
Jul 25, 2006 03:56 PM
kartman
May 11, 2006 01:18 PM
kinvid22
18
Oct 23, 2003 12:59 PM
wizzards581
Jul 13, 2002 07:30 PM
