EF-1 Turbo rods VS Eagle rods.
Old Oct 19, 2003 | 08:24 PM
Hoosier Daddy's Avatar
Default EF-1 Turbo rods VS Eagle rods.
My only experience with EF-1 is cams. I'm happy with them. Any input on their rods would be appreciated.
Old Oct 19, 2003 | 08:29 PM
TurboTegB18c's Avatar
Default Re: EF-1 Turbo rods VS Eagle rods. (Boost Creep)
The Ef-1 rods are machined better and have the larger 10mm rod bolt which are known to fail in the eagles. Hit me up if u want to purchase a set. Paul
Old Oct 28, 2003 | 05:02 AM
guymosiris's Avatar
Default Re: EF-1 Turbo rods VS Eagle rods. (TurboTegB18c)
Do Eagles use ARP rod bolts? What about the ef's? I am also in the middle of rod choice decision between Crower, Eagle, and ef-1. Crower's are too expensive for me. How much do ef-1's run for? Thanx
Old Oct 28, 2003 | 05:08 AM
COOKIEPUSS's Avatar
Can you pm me a price for CP pistons around 9.2:1 for b16a, and EF-1 rods. Also do those rods include ARP bolts?
Thank you, I'm trying to price out my parts, to stay within my budget.
Thanks again
Gene
Old Oct 28, 2003 | 05:31 AM
ehhguy's Avatar
Default Re: EF-1 Turbo rods VS Eagle rods. (COOKIEPUSS)
I heard that Rocket will be comparing his EF-1 Turbo rods to the Eagle rods very soon. I would just try to hold out on buying either rod if you can.
Actually, I found this post:
http://ef-1.zeroforum.com/zerothread?id=534
Old Oct 28, 2003 | 07:18 AM
Default Re: EF-1 Turbo rods VS Eagle rods. (guymosiris)
Both eagles and the ef-1 rods use arp bolts, However, the ef-1 rods uses larger arp rod bolts. Paul
silverskateEF9
31
Oct 6, 2007 07:13 PM
ARACER25
Oct 19, 2003 09:22 AM
liam821
Aug 13, 2003 04:32 PM
Toretto
Feb 25, 2002 05:54 AM
