2 step poll? techniques
Old Aug 5, 2003 | 11:27 PM
turbospool's Avatar
Default 2 step poll? techniques
Do you guys like to set your 2 step a little bit higher so you can hold the switch/button until you feel like you have traction? Or do you set the 2 step to exact rpm where you can just let off the clutch and floor it? Which one would yeild better results in 0-60? Thanks.
Old Aug 6, 2003 | 12:01 AM
flip1199's Avatar
Default Re: 2 step poll? techniques (turbospool)
well when i ran at the track with the 2-step, i had it set to about 45-4800. I was flooring it then just dropped the clutch. that netted me low 2.1 on drag radials. but then again that was when i was still having problems with coupling blowing up.
Best thing to do i try both and see what works best for you.
Old Aug 7, 2003 | 12:12 AM
turbospool's Avatar
Default Re: 2 step poll? techniques (flip1199)
thanks, anybody else have input?
Old Aug 7, 2003 | 10:23 AM
vtecman253's Avatar
how much do 2 steps usually run?
Old Aug 7, 2003 | 10:30 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: 2 step poll? techniques (vtecman253)
I just hold it at 6k, and dump the clutch.I tried a 7k pill once, and it blazed the slicks too much, so i went back to 6k, been netting 1.72 60'ft's all day
Old Aug 7, 2003 | 12:11 PM
turbospool's Avatar
Default Re: 2 step poll? techniques (SIXTYdashONE)
so u dont hold you 2 step button down until you get traction?
Old Aug 7, 2003 | 12:33 PM
HT's Biggest Loser
No way man, either it hooks, or i feather the gas for a second. It will hook.
Old Aug 7, 2003 | 01:14 PM
kwik93si's Avatar
i have mine set at 6000 and just pop the clutch i run 1.6's all day. my best is a 1.63
Old Aug 7, 2003 | 05:04 PM
turbospool's Avatar
Default Re: 2 step poll? techniques (kwik93si)
what i do is floor the gas pedal, hold my 2 step button at whatever its set at, which is a lil high causing my wheels to sping, then i would pop the cltuch and instead of feathering the gas, i hold down the button until it hooks. would i get better 0-60 if i set the 2 step lower and just let off the button at the lauch and just feather the throttle?
Tjabo
Nov 19, 2009 11:36 AM
black sohc civic
Apr 8, 2004 11:22 PM
.M.
Mar 28, 2004 03:07 AM
eddiecut
Sep 19, 2003 12:43 PM
JDM R98
Jul 24, 2001 11:41 AM
