1997 honda prelude idle problems with aem ems
Old Mar 17, 2008 | 04:50 PM
samowen's Avatar
Default 1997 honda prelude idle problems with aem ems
i have been racking my brain with this aem ems trying to get the idle down past 1100 rpm without stalling i have checked my timing twice i have tryed talking with aem to come up with a solution for this problem i get timing errors which aem says its due to my distributor they told me to buy a new honda distributor but what if that dosent solve my problem i mean befour i put in the aem ems i had a vafc i was using to tune down the injectors just to get by and i never had a problem with the idel aem say that there ems is real sensitive to the singnal in the honda distrubtor but they never have been able to come up with a good solution ive just spen over 1500 dollars on this setup and i believe that there are good things to come with this managment but iam very dissatisfied with the tech support if any of guys have any ideas on what the problem is please reply back
18g greddy turbo kit
450cc dsm injectors
255 walburo pump
lc1 wide band
Old Mar 17, 2008 | 05:16 PM
93-lsvtec-eh2's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (samowen)
i would get the dizzy
i have heard of lots of guys having to buy new distributors because they had a distributor king dizzy. i ran into the same problem on the dyno with my engine and my buddy had to same problem with his car
Old Mar 17, 2008 | 07:26 PM
samowen's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (93-lsvtec-eh2)
so what do i need honda distributor or after market im not to sure what to do
Old Mar 17, 2008 | 08:17 PM
jjspec's Avatar
I am still on a factory made Honda H22 dizzy. Made >800 whp last year.
Old Mar 17, 2008 | 08:44 PM
streetracer6rpt's Avatar
sell it and buy hondata
Old Mar 18, 2008 | 03:03 AM
JDogg's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (streetracer6rpt)
if you are getting timing errors then the dizzy is a pile, as are most honda dizzys.
if you switch to hondata it will "fix" it, but you still have garbage signal going into your ecu.. it dosnt matter what ecu it is, GIGO
id call up tony1 and get a cam trigger instead of buying a new distributor.
Old Mar 18, 2008 | 06:06 AM
samowen's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (JDogg)
thank you so much for the info on the trigger sensor i have heard many problem with it so how much are they and are they a bitch to install
Old Mar 18, 2008 | 06:24 AM
samowen's Avatar
just looked in to that looks like alot of tearing down icant believe that aem would sell this product with out researching and vigours testing iam very dissatisfied with this company
samowen's Avatar
Old Mar 18, 2008 | 07:42 AM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by samowen &raquo;</TD></TR><TR><TD CLASS="quote">just looked in to that looks like alot of tearing down icant believe that aem would sell this product with out researching and vigours testing iam very dissatisfied with this company </TD></TR></TABLE>
aem isnt the only ecu that has this problem, any and all standalones (even motec), if they can even use the stock distributor, have issues with the stock distributor's signal here and there.
like Jdogg said, garbage in, garbage out.
i rev to 11k on an OEM ITR p73 distributor on an AEM EMS 30-1040U box w/o any issues and idle my car ~700.
Old Mar 18, 2008 | 04:12 PM
samowen's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (wHOAlly)
i understand but 5 gen prelude crank trigger is on balance shaft thats alot of work for somthing you just plug in and also what distributor are you using what do i need for obd2 also i talked to aem tech and he said to send it back and they were going to check the resistors in the box
Old Mar 18, 2008 | 04:38 PM
jjspec's Avatar
The cam position sensor is in the distributor, not one the crankshaft. Those two are the Number One Position and Crank fluctuation sensor.
Old Mar 18, 2008 | 07:14 PM
Turbo-charged's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (jjspec)
+1 for the T1 cam trigger.
my car wouldnt rev past 10psi with out breaking up and missfiring with AEM on a stock distributor. put the T1 kit in, had no missfires, even past 40psi.
H22's are very touchy
Old Mar 19, 2008 | 05:06 AM
JDogg's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (Turbo-charged)
with the t1 trigger you can still use the distributor for spark.... or you can use this
http://www.aempower.com/ViewCa...D=122
but you have to go coil on plug if you use that since it replaces the distributor.
Old Mar 19, 2008 | 10:42 AM
JDogg's Avatar
basicly changing the resistors make it less sensitive so it can deal with a weak shitty signal.. if you are ok running your car with a weak shitty signal go for it, but dont blame us or aem when your **** blows up b/c your distributor is a pile of crap
Old Mar 20, 2008 | 06:33 AM
samowen's Avatar
right i understand your point but when i call the tech line they should atleast try to come up with a solution for this problem cause i no this isnt the first time this has happened so what are your recomendations for a distributor
Old Mar 20, 2008 | 06:55 AM
tony1's Avatar
The solution is getting rid of the stock distributor. The aem doesn't do good with the signals it produces and will run much better when it has a clean input signal.
This will solve your problems.
http://www.t1raceparts.com/product_p/t1cth22.htm
Old Mar 20, 2008 | 07:41 AM
bambooluv's Avatar
Default Re: 1997 honda prelude idle problems with aem ems (tony1)
Tony for making H-series parts.
Even though I have given up the H in favor of
a B still
Pdang
Old Mar 20, 2008 | 10:15 AM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by samowen &raquo;</TD></TR><TR><TD CLASS="quote">right i understand your point but when i call the tech line they should atleast try to come up with a solution for this problem </TD></TR></TABLE>
becuase it ISNT a solution, its a bandaid that has MAYBE a 30% chance of working? and even then, its questionable.
from what ive noticed, some distributors just work, and some dont.
if you talked to Garvin on the tech line, he himself has run into this problem on his personal car, hes tried 3 differnt distributors, ask him what his final solution was....he put on the new AEM EPM and COP. ask him about it.
underpressure02
May 4, 2011 12:45 PM
WalkerGSR1
Jun 22, 2006 08:38 PM
Boostage
Jun 12, 2006 08:18 PM
boostedlude01
Mar 23, 2005 08:50 PM
E Swift
Feb 11, 2004 05:33 PM
