Bullseye Power Super 50
Wassup HT I got a bullseye power super 50 t3/t4 turbo 4sale.This Turbo is fantastic turbo with a stage 5 turbine wheel with extended tip compressor wheel 360 journal bearing freshly rebuilt with bullseye power components and both wheels ceramic coated this Turbo has 0 miles after rebuild and balancing this thing flows 54 lbs a minute and spool is almost instantaneous Pm me
Looking 550 obo shipped
For comparison it will spool as fast as a 50 trim and out flow a 60 trim garrett
Re: Bullseye Power Super 50
I left my number for a reason yes it has slight side to side play but that is because Turbo was rebuilt and it is completely dry which is normal for journal bearing turbos since the bearings ride on oil once u run oil threw it the play goes away in and out movement is non exsistent this Turbo is good for 450-550 whp range can boost over 30 psi with no problem
jdm_vtec
11-17-2006 03:37 PM
