Xbox too much?
Old Apr 29, 2004 | 09:46 AM
nver2's Avatar
Default Xbox too much?
Is it true that the Xbox pulls more current then the PS2. My friend said he had to take out his Xbox. Cause it killed his battery and altenator. He also said that it would just quit playing and stuff like that. So he switched to PS2. What inverter do I need to play the Xbox
Old Apr 29, 2004 | 09:57 AM
yonnage's Avatar
Default Re: Xbox too much? (nver2)
Probably, don't forget that the XBOX is basically a PC. HD included and all..
Old Apr 29, 2004 | 10:16 AM
nver2's Avatar
Default Re: Xbox too much? (yonnage)
yeah thats what he said. I really dont want a PS2. Anyone have any ideas
Old Apr 29, 2004 | 12:20 PM
t0p_sh0tta's Avatar
It only kills your battery when the car is off. ANY electronic accessory will do that. It can't possibly pull more ampherage than a small amp, so I don't see how it would affect the alternator.
Old Apr 29, 2004 | 01:56 PM
nver2's Avatar
Default Re: Xbox too much? (t0p_sh0tta)
so just dont use it when the car is off and it wont kill the battery?
Old Apr 29, 2004 | 07:11 PM
nontent's Avatar
if the alternator is running it will be supplying the power... if the alternator is not running the battery will be supplying the power..
so if the car is off, and you run the xbox the battery is gonna drain pretty quick, while if the car is on and you're running the xbox the battery won't be draining at all (unless your alt can't handle the load, in which case it may drain a bit)..
Old Apr 30, 2004 | 08:43 AM
yonnage's Avatar
what inverter do you have now?
ALLDAY-24
18
May 3, 2011 08:25 AM
9sludei0
Aug 29, 2010 12:22 PM
aSDthing
Feb 12, 2008 06:03 PM
CRXDrew
May 11, 2005 01:24 AM
mjrage
18
Jun 25, 2004 06:28 PM
