Will remote start work on 02+ SI (Coded Key)
Old Oct 7, 2004 | 12:57 PM
Boston_George's Avatar
Default Will remote start work on 02+ SI (Coded Key)
Hi Guys,
I'm looking into buying a remote start for my 02 Si but I was wondering if it can be done.... I'm not talking about the pysical wiring part... I know that will work... But will it start without having the coded key in the ignition? The 02+ SI's anlong with S2000's and RSX's, and even 97-01 preludes have a coded keys. Does anyone have a remote start in a honda with a coded key ignition? ... Thanks.
Old Oct 7, 2004 | 01:25 PM
KayOs's Avatar
Default Re: Will remote start work on 02+ SI (JRSCB16ARipster)
It will work with the use of a bypass transponder.
Old Oct 7, 2004 | 03:25 PM
killlaalex's Avatar
Default Re: Will remote start work on 02+ SI (KayOs)
hi my names alex n im new to this forum.
i just got a 2002 Civic Si also, and i bought a audiovox prestige informer series alarm/remote starter. and i know it can b hooked up to a manual transmission, i was jus wondering if any of u guys no how to hook the remote starter to bypass a clutch, please reply to me if you know how to
Old Oct 7, 2004 | 08:06 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSCB16ARipster &raquo;</TD></TR><TR><TD CLASS="quote">Hi Guys,
I'm looking into buying a remote start for my 02 Si but I was wondering if it can be done.... I'm not talking about the pysical wiring part... I know that will work... But will it start without having the coded key in the ignition? The 02+ SI's anlong with S2000's and RSX's, and even 97-01 preludes have a coded keys. Does anyone have a remote start in a honda with a coded key ignition? ... Thanks.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">It will work with the use of a bypass transponder.</TD></TR></TABLE>What he said http://www.dei.com
I'm looking into buying a remote start for my 02 Si but I was wondering if it can be done.... I'm not talking about the pysical wiring part... I know that will work... But will it start without having the coded key in the ignition? The 02+ SI's anlong with S2000's and RSX's, and even 97-01 preludes have a coded keys. Does anyone have a remote start in a honda with a coded key ignition? ... Thanks.</TD></TR></TABLE> You will need a SPST or SPDT relay, trigger with "on when starting" output of remote start relay will do what clutch switch does only when remote starting. link http://www.the12volt.com click on relay basics, to the left 94
Old Oct 8, 2004 | 06:00 AM
Nice.. Thanks for the info guys... Does anyone know of an alarm that I can purchase with all of the components I need included in the package... Brand & model would be great... I'm looking for an alarm/ remote start combo... Thanks again.
Old Oct 8, 2004 | 07:47 AM
fcm's Avatar
fcm
Old Fart
Default Re: (JRSCB16ARipster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSCB16ARipster &raquo;</TD></TR><TR><TD CLASS="quote">Nice.. Thanks for the info guys... Does anyone know of an alarm that I can purchase with all of the components I need included in the package... Brand & model would be great... I'm looking for an alarm/ remote start combo... Thanks again.</TD></TR></TABLE> You may be able to get it as a package from a car audio/alarm shop, no system will come with all the components, as differant cars need differant components. 94
Old Oct 8, 2004 | 08:23 AM
Odessa's Avatar
Default Re: (fcm)
JRSCB16ARipster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and even 97-01 preludes have a coded keys</TD></TR></TABLE>
Why so unrespectful?
fcm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> You will need a SPST or SPDT relay, trigger with "on when starting" output of remote start relay will do what clutch switch does only when remote starting</TD></TR></TABLE>
That's what everyone says, but I never had to use one (relay), it worked without it...besides, I'm also powering a bypass at the same time and it works...getting over 12v+ on the dmm.
Old Oct 9, 2004 | 05:55 AM
rjr162's Avatar
Default Re: (Odessa)
uh, I doubt you're getting it to work without the relay.. if you are then that car is a fluke. My 97 prelude I had to use the relay trick (connect 30 to one side of the clutch switch, and 87 to the other side, 85 to +12 either ignition or constant, and 86 to the - status output of the remote start). I also know the switch you need is the one back in farther, it's the one that only gets "pushed" when the clutch is to the floor. The other switch closer to the drviers seat is the cruise control kill switch.
Old Oct 9, 2004 | 06:51 AM
fcm's Avatar
fcm
Old Fart
Default Re: (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">uh, I doubt you're getting it to work without the relay.. if you are then that car is a fluke. My 97 prelude I had to use the relay trick (connect 30 to one side of the clutch switch, and 87 to the other side, 85 to +12 either ignition or constant, and 86 to the - status output of the remote start). I also know the switch you need is the one back in farther, it's the one that only gets "pushed" when the clutch is to the floor. The other switch closer to the drviers seat is the cruise control kill switch.</TD></TR></TABLE> No,O is right ,in most cars all the clutch switch does is trip a relay,[the other way is to run "starter" wire through switch] and the 250Ma output of a on when starting line of a remote start will trip up to 3 or 4 relays no problem, I always use a relay because the relay isolates the the remote start CPU from the car. 94
Old Oct 9, 2004 | 07:20 AM
rjr162's Avatar
Default Re: (fcm)
EDIT&gt;&gt; I guess I mis-typed what I ment to put... you can do it without the relay, you're right, but it's best to use it so if someone hops in your car, turns the key w/o the clutch in, the car doesn't fire up and hop forward. That way the clutch kill switch still works.
If you don't mind this "issue", then you could tag the ignition output to your clutch switch
myaccord2004
Feb 9, 2018 02:12 PM
HiProfile
Audio / Security / Video
Dec 25, 2008 03:56 PM
bluberry4dr
Nov 15, 2007 09:30 PM
Jap_Spec_Imports
30
May 26, 2006 05:43 PM
incogNitto
Jul 14, 2002 12:58 AM
