AvantGaurd 4 Testing Problems
Old Jul 10, 2002 | 03:29 PM
incogNitto's Avatar
Default AvantGaurd 4 Testing Problems
Just hooked up my AvantGaurd 4.
When I try to do a remote start from the CliffNet software, the starter doesn't spin at all. It goes through the procedure as if it was going to do a remote start. When I click pulse starter, the starter does spin.
When I do an unlock from the software, the doors unlock and the lock again. I've heard something about this before, so it might not be related to the alarm.
I'm doing all of this from the software because when I try to program the remote from the software it says to press a button on the remote, but the alarm/software doesn't respond. How can I program a remote manually outside the software?
Old Jul 10, 2002 | 04:27 PM
incogNitto's Avatar
Default Re: AvantGaurd 4 Testing Problems (incogNitto)
Got the remote and door lock problems fixed.
Anyone have and ideas on what the remote start problem is. I tried to do the RPM programming both on software and using the buttons, and it seemed to accept but still no start.
Old Jul 10, 2002 | 06:22 PM
incogNitto's Avatar
Remote start won't work from the remotes. I can enable igntion in the CliffNet software, crank the engine (via the software) and it will start and run, so the wiring must be correct. However it won't remote start from the remote or by clicking the Start Engine button in the software.
Old Jul 11, 2002 | 11:34 AM
incogNitto's Avatar
ttt
Old Jul 13, 2002 | 04:03 AM
Ch33se's Avatar
New User
do you have the instructions??? if you dont....I do....let me know. also the cliffnet software how does that work? do you need a plug? or wire? anyhow let me know if you need the instructions...i have the AG4 myself. I dont know how to fix your prob tho
Old Jul 14, 2002 | 12:58 AM
Yeung's Avatar
my friend had a similar problem before... he got his alarm turned off... but every worked fine including lock/unlock...... but just cant remote start
he took his car back to the shop... that guy turned it on and everything worked perfectly
94 accord typeR
Audio / Security / Video
Sep 9, 2014 08:18 AM
speed_bumps_suc
Feb 28, 2010 06:26 PM
allmotor.net
Jan 25, 2004 01:51 PM
mindogg
Sep 9, 2003 05:18 PM
43MA
Jan 28, 2003 05:20 PM
